Best lowering spings for 2003 Cobra - Mustang Evolution
Old 11-17-2010, 12:22 PM   #1
drusmith's Avatar
Send a message via Yahoo to drusmith
Hey everyone,
I will be installing new springs over the winter and was wondering what the best is and who has what and how easy is the install?
let me know!
Regards,
drusmith is offline   Reply With Quote
Old 11-17-2010, 12:46 PM   #2
Re: Best lowering spings for 2003 Cobra
Piece of cake to install. Your best bet is the H&R race springs. They don't come in a convertible spring rate, but that's fine. Spector has them on his car so you can see the amount of lowering they give.
My car has cut stockers right now...I have the front coil over kit to install but am waiting till I get the rear kit and do it all at once.
If you want to dump a lot of money, coil overs would be your best bet. However, you're going to drop a good bit of coin on both the front and rear kits...specially if you want to keep good street manners or handle turns moreso than going straight due to having to replace the shocks and struts (maximum motorsports doesn't recommend stock vert shocks/struts with the needed spring rates for a good twisty car).
American muscle is supposed to have a discount code for members that I'm sure we have to PM them for....Brent will know more about the status of this as it is new. However, if not, PM me and I'll give you a discount code to a couple other sites where you can get the springs as well. One is $10 savings with free shipping, the other is 3 or 5% plus shipping.
ALSO: Do you have the full mod list for your car? Like, did they replace the IRS bolts at all? If not, you'll want to do this as well.
Old 11-17-2010, 01:08 PM   #3
most with coil overs dont like them for noise and such, steer clear of those (I would). Go with H&R race leave one isolator out in the front leave both in for the rear (use the OEM isolators dont buy different than factory ones if you replace them).
Mine is 26.0 front / 26.5 rear (ground to under edge of middle of fender lip)
They are 720lbs front and rear but ride quite well (500 is stock for 03 cobra verts front/rear)
as said install is very easy, I wrote an install article you can read over in the article section. The IRS you just need to remove the catback, unbolt the shock, unbolt the back IRS frame bolt (where the button head bolts or low profile head bolts go) and swing it down a bit and the springs fall out
Great time to do an IRS brace if you have not, button head/low profile bolts, and the CORRECT 14mm front IRS frame bolts.
Old 11-17-2010, 01:08 PM   #4
drusmith's Avatar
Thanks PureVenom!!! That is very helpful. So you are saying I can not used the stock struts with the new springs. I have done this before on other cars and I did not need to.
Old 11-17-2010, 01:14 PM   #5
drusmith's Avatar
SpetorV,
Always helpful as well! Your car looks bad a** so I will probably go with what you have. I hope one day to meet all you guys but it might be difficult since I am in MI. Oh and I will check out your article as well.
Old 11-17-2010, 01:55 PM   #6
I've heard the same thing and actually talked with MM about it. It appears that many go with 12-14" long springs when they do coil overs. MM recommends 10" springs. The longer springs bow and bang around causing noise then people complain about it.
Old 11-17-2010, 01:56 PM   #7
Originally Posted by drusmith View Post
SpetorV,
His car is ok...terrible color though....
Old 11-17-2010, 02:01 PM   #8
drusmith's Avatar
HA that's funny!
Old 11-17-2010, 02:05 PM   #9
MM said the shock/struts were ok rate wise to work with the H&R race springs so I didnt change mine out they are still the OEM ones.
Old 11-17-2010, 02:08 PM   #10
drusmith's Avatar
Purevenom & SpetorV,
Thank you my "03 drop top brothers" LOL
Old 11-17-2010, 02:13 PM   #11
drusmith's Avatar
Ok I found them for $235 s/h included on ECS Tuning. Can I get them any cheaper anywhere else?
Part # is H&R race springs 51650-88
Old 11-17-2010, 02:13 PM   #12
drusmith's Avatar
Sweet, thank you! That is what I wanted to hear!
Old 11-17-2010, 02:21 PM   #13
Right, I was referring to the coil over rates only.
PM NQSperformance (John@NQS is his user id on here). He is a site sponsor. I was able to save a good bit on parts from maximum motorsports...His website has them at 259 for the springs, however he does have a discount for members.
Like was mentioned before though, look into the low profile IRS bolt (rear of IRS frame) and the correct 14mm IRS bolt (front of IRS frame). It will prevent clunk and make room for wider meats...assuming this is not done already. Maximum Motorsports has these bolts.
Old 11-17-2010, 02:23 PM   #14
ive heard the button head bolts MM sells round out~ there are other alternatives to them.
http://fulltiltboogieracing.com/ may have them
Old 11-17-2010, 02:25 PM   #15
drusmith's Avatar
PureVenom,
Is this what you are referring to about replacing the IRS brace?
2003-04 Mustang Cobra Billet Flow IRS Brace
Old 11-17-2010, 02:26 PM   #16
yea thats the brace I have, here is their site link IRS Brace
price it on a few sites as well as lethalperformance.com see where the best deal is. You can get them in sonic blue I think but you cant see them from behind the car.
Old 11-17-2010, 02:26 PM   #17
Full Tilt Boogie Racing may have them
What do you mean, round out?
And full tilt only has the front bolts...not the rears.
Old 11-17-2010, 02:27 PM   #18
Ive just heard the allen socket hole on the bolt rounds out if you need to remove them~ not sure if thats true.
Old 11-17-2010, 02:29 PM   #19
PureVenom,
I think it was spec that suggested it...maybe I did...but yes, you want that brace if you are currently unbraced. You should be able to get it directly from billetflow without much issue.....lethal performance also has it and is 159 but I have a code to save 5%....so you may want to compare prices with shipping to get the best deal.
Also, like spec said, don't worry about color. The only time you can see it is if you are laying under the car or the rear end is out of the car.
Old 11-17-2010, 02:30 PM   #20
I had no issues removing mine, but I've only had them out once....
Old 11-17-2010, 02:31 PM   #21
drusmith's Avatar
Thanks guys! It looks like I can order it in Sonic Blues as well! OH YEY!!!!!!
A picture is worth a thousands word! Good link SpectorV
Old 11-19-2010, 04:06 PM   #22
Dang...I'm late on the draw here lol.
H&R race springs definitely. Both bottom isolator in front and both in rear.
Stock shocks/struts are fine, I'm still running mine.
Billetflow brace is the one to get.
The MM low profile bolts are fine. I've taken mine in and out probably a dozen times with no issues. I believe people are stripping them out by not taking the load off the bolt before attempting to remove them. You have to put a jack under the IRS and lightly raise to take the load off. I've never ran into any issues putting them in or taking them out.
Old 11-21-2010, 07:02 AM   #23
edross's Avatar
spector talked me into H&R race springs and i love it, nice drop, by the way what do i do with the old springs? does anybody have any use for them
2003 gt, sct custom tuned by VMP, k&n fipk, upr o/r x-pipe, dynomax turbo mufflers, mm c/c plates, mm full length subframe connectors, h&r race springs, bullit rims 18x10 rear 18x9 front, 4.10 gears, 20% tint, 9 inch shorty antenna
edross is offline   Reply With Quote
Old 11-21-2010, 05:26 PM   #24
Mine ended up in the dumpster after moving twice...
WTB: Lowering Kit and Cobra Fogs... 94Stang504 Mustang Parts for Sale and Wanted 39 08-01-2008 12:01 PM
2003 Ported and Spray'd Cobra vs 2003 Turbo Cobra Whipple Mustang GT vs FRC Corvette BoostedB18c Pictures and Videos 0 06-07-2008 10:07 PM
Cobra R bk w/ lowering srpings quest. douGT Mustang Audio & Video 14 06-28-2005 09:57 AM
03:26 PM
