Grinding when shifting--what is it - Mustang Evolution
Old 11-24-2010, 06:08 AM   #1
I test drove a used 2000 GT with 100K miles,,, a couple times heard/felt some gear grinding when downshifting from 5-4th...not bad, but it happened twice, at low RPM...
Original clutch... could this be a sign of a clutch problem? Car has not been driven hard, raced, etc. I hesitate to buy the car because of this, unless the price is really really right. Owner denies the problem, says it never happened to him. I admit, it was at low RPM, I was just going thru the gears to see what they were like.
Comments?
SunCity85373 is offline   Reply With Quote
Old 11-24-2010, 07:20 AM   #2
Re: Grinding when shifting--what is it
syncros are going bad or the clutch is not going into neutral all the way when its pushed in~ self adjust the clutch to see if its an issue with the clutch cable not being pulled enough when you push the petal in.
The stock setup you need to hold the clutch to the floor with one hand use the other hand on the quadrant (near the gas petal) and hold against the motion as you ease out the clutch petal and it will click (hold the quadrant half moon shaped plastic thing with a little gear on the end of it where the clutch cable goes over the quadrant as well) do a couple clicks see how that feels.
Old 11-28-2010, 07:42 AM   #3
Spectorv is right. I can tell you right now its probably the syncros though.
punishersvt is offline   Reply With Quote
Old 12-21-2010, 01:15 PM   #4
Mine did that from second to third but I changed out the fluid to amsoil and ran it half a quart low and it seemed to fix the problem. However if it's the original clutch this is around the mileage that they fail at
Old 01-06-2011, 12:14 AM   #5
i had the same problem shifting from first to second. it was so horrible i thought i was gonna have to rebuild it. i drained the fluid when i installed a steeda triax shortthrow shifter and filled it with royal purple. i havent grinded second gear or any other gears since. RP works like magic!
96greenGT is offline   Reply With Quote
Old 01-06-2011, 07:22 AM   #6
MonteCitan's Avatar
Comments?
I'm thinking its a combination of transmission design and synchro wear..
On my 01 GT, for some odd reason, if I put the car in 4th to 5th at low speed, then decide it's too high a gear for the speed before letting the clutch out and putting the shifter back to 4th I get a grind as well, it does not happen going from any other gear, and again only happens if I don't let the clutch out
I don't let it bother me, it doesn't affect drivability of the car at all, and I know my clutch is good
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 01-06-2011, 07:44 AM   #7
they say the 5th gear syncro is the weakest, but it might just be the gear itself is the weakest since its the smallest. NEVER power shift (or shift hard) into 5th or any overdrive gear.
Old 01-06-2011, 03:39 PM   #8
stampde's Avatar
yup what spectorv said !!!!!
2011 GT Auto
Old 01-06-2011, 04:21 PM   #9
MC770's Avatar
How much is it to fix a syncros, looking into buying a 95 v6 that needs a new syncros
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Grinding/Bearing noise from 88 GT Jeffrey2 1979-1995 Mustang GT 3 08-23-2010 05:38 PM
grinding sound elystarz New Member Introductions & Greetings 1 08-15-2009 06:57 PM
Grinding in second BAgee87 1996-2004 Mustang GT 4 10-14-2008 09:05 AM
grinding in third?? bluestang1724 1979-1995 Mustang GT 9 02-10-2008 06:16 PM
grinding from rear gt4me 1996-2004 Mustang GT 8 11-29-2004 10:36 PM
03:50 AM
