Idle surge with a/c or heat on only - Mustang Evolution
Old 11-24-2010, 10:47 AM   #1
Need help:
I have a 2002 mustang gt i replaced the iac the egr valve and sensors 02 sensors maf throttle position sensor spark plugs checked for vac leaks and nothing helped. The car idles fine unless i have the a/c on when i come to a stop the idle will jump up to 1000rpm and back down to 650 700 and continue going up and down until i continue driving again also the car is an automatic and when it shifts into overdrive it will hesaitate and then buck into gear. The car also tends to hesitate when I really step on it you can hear the air being sucked in but takes a min to get going any ideas would be a great help im running out.
roush727 is offline   Reply With Quote
Old 11-24-2010, 11:15 AM   #2
GUDNEVL's Avatar
Re: Idle surge with a/c or heat on only
i would think(of course i may think wrong),that the a/c high idle is pretty normal,the air sound when you get on it,do you have a cold air intake?
1989 mustang gt,short headers,3.08 gears,off road h pipe,flows,cold air intake,smog pump delete,fresh tune up,push button start,gt fog light fix ,everything else pretty much stock
most recent mod:blown head gasket
GUDNEVL is offline   Reply With Quote
Old 11-25-2010, 11:32 AM   #3
yeah i know the idle should raise a little bit with the a/c on but it is surging it spikes up to about 1000 rpm and the drops to about 650 at a complete stop then right back up to 1000 a sec later and back down to 650 this continues until i resume driving
Old 11-27-2010, 12:34 PM   #4
Tape's Avatar
when your low on refrigerant it will do this like you explain "650 at a complete stop then right back up to 1000 a sec later and back down to 650" I would bet your a couple of ounces low. when everything is serviced it will do it but just not every second.
Tape is offline   Reply With Quote
Old 12-09-2010, 09:11 AM   #5
Exclamation Re: Idle surge with a/c or heat on only
Hello to everyone, I'm from Guadalajara Mexico and I own a 00 GT, I just have a similar problem, but mine goes down to even 250rpm, then goes up to 1500 and back to 650 when A/C is on, I'd just like to know whta could be wrong.
Thanks for your replies!!!!
Wakarimasen_san is offline   Reply With Quote
Old 12-09-2010, 09:35 AM   #6
yea as said get the system checked to see if its low and add if it needs it then check it out.
Old 12-12-2010, 05:24 AM   #7
dshaley77's Avatar
Mine does this too...I added refrigerant and it fixed the problem. Then about a month went by and it started again. I'm almost 100% sure there is a leak somewhere....just havnt gotn around to get it checked out yet.
dshaley77 is offline   Reply With Quote
Old 12-14-2010, 01:50 AM   #8
Need help:
I would try cleaning the throttle body first. The iac may be compensating for your idle already, and may not have enough when ya kick the a/c on. You may also want to check your ground wires. When you turn the heat on, is the a/c light still on? Basically are you just turning the knob from blue to red? If so the compressor will still be turning.
2004 Cobra...
Mods: Kenne Bell 2.2H, Fore return system, SCT tuned, 26 spline input shaft, and DSS Pro-level axles.
http://www.facebook.com/LangsStangs
lxlaw is offline   Reply With Quote
heat shield Senorjizzy Pre-2005 V6 Mustang 2 10-10-2009 11:50 AM
TF Track heat GOTGREENS 1996-2004 Mustang GT 4 03-09-2008 01:33 PM
06:19 AM
