need opinions on shortblock - Mustang Evolution
Old 12-07-2010, 11:17 AM   #1
quickndslick2's Avatar
Question need opinions on shortblock
Honestly, what do you guys think about this choice of bottem end? pros and cons? anything you guys would change?
Brand New Cast Iron 2004 Cobra Block, torque plate bored and honed
*New 4340 Forged 3.543 stroke Cobra Crankshaft w/micro polished journals at no extra charge
*New 4340 5.933 MMR 900HP H-beam Rods w/ARP rod bolts ( These rods are shotpeened, magnafluxed and weight matched to bring you the finest H-beam rod available for your 4.6)
*New Forged Manley pistons (High or low compression)
*Total Seal file fit rings (precision file fit to your application, nitrous, blower, turbo or N/A)
* Clevite tri-metal Rod and Main bearings
quickndslick2 is offline   Reply With Quote
Old 12-07-2010, 11:43 AM   #2
Upgrade to the boss 5.0 big bore.
Old 12-07-2010, 02:13 PM   #3
Re: need opinions on shortblockk
[QUOTEUpgrade to the boss 5.0 big bore][/QUOTE]
cant afford that now
Old 12-07-2010, 02:32 PM   #4
It's only a $1400 option or something like that from MMR...if you're dumping 3k on a short block anyhow...I'd just save a few more pennies and get the big bore option. It's what I am doing currently as well....just going to save a little longer and get the big bore.
Old 12-07-2010, 02:54 PM   #5
ok i get you but this is my daily driver and i blew my botten end ive been without a car for acouple weeks now so i need to get this done asap, will this give me more power than stock?? will it hold power and not blow?
Old 12-07-2010, 03:33 PM   #6
It will survive more power as it is a proven cobra block. It might bump your power a little due to a change in compression ratio depending on which piston dish you select. If you go with stock compression, it won't bump your power at all, but will be ready for more.
Old 12-08-2010, 05:46 AM   #7
Sounds like a good deal to me.
Straublittleman is offline   Reply With Quote
Max factory shortblock HP and RPM Gyro Pre-2005 V6 Mustang 1 05-23-2008 06:36 PM
Shortblock or rebuild? sir2much 1979-1995 Mustang GT 14 03-04-2007 11:00 PM
So finally got a picture of the shortblock Brent Pictures and Videos 25 08-04-2006 04:11 PM
Looking for a 4.2 shortblock in IL petrey10 Mustang Parts for Sale and Wanted 3 11-16-2005 08:10 AM
need some guidance, 94 shortblock tire Pre-2005 V6 Mustang 0 02-16-2004 10:54 AM
03:31 AM
