Strange squeak - Mustang Evolution
Old 12-12-2010, 06:39 AM   #1
dshaley77's Avatar
Strange squeak
Hey guys,
When I start up my 03 GT there is a slight squeak noise. I thought it was due to the belt, but when I popped the hood I didn't hear it any more.
When I got back inside, I pushed my clutch in and the squeaking stopped. I let the clutch out in N and it started right up again. It only does it from a cold start, once the engine warms up it stops. Not exactly sure what's goin on, any ideas? Also I live in FL so in never gets too cold. (except For the past week or so) An It's been doing it now for about a month.
dshaley77 is offline   Reply With Quote
Old 12-12-2010, 12:37 PM   #2
MonteCitan's Avatar
Re: Strange squeak
My guess is, that would be your throwout bearing..
With no load on it (clutch pedal out..) it's spinning independently.. As soon as you load it up it'll go away.
My guess also is it will get worse over time, it may be going away now after heating up as metal expands/contracts/etc...
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 12-12-2010, 02:49 PM   #3
dshaley77's Avatar
Is that a tough fix?
Old 12-12-2010, 05:33 PM   #4
Badinuf's Avatar
Re: Strange squeak
Depends on what you consider tough. You have to drop the transmission to get at the throwout bearing. If it was my car I would probably replace the clutch while I was in there. I've only replaced one clutch in my life (on my RX7) wasn't that hard but you definately need a buddy to help.
Chuck
2007 Torch Red Mustang GT, Parchment Leather, Saleen Supercharger, SCT X-Cal Programmer,brenspeed.com tunes, Tuned by X-Act Dyno (Tempe, Az) 425rwhp, 4:10 Gears, Axel-back MAC exhaust, Dashhawk OBD-II Computer Monitoring System, Sequential Tail Lights, Halo Driving Lights, Eagle Eye Headlights with 6000K HID's, Clear Turn Signal Lenses, Projector Switchback Bulbs, Painted White LeMans Style Stripes, CDC Aggressive chin spoiler, Billet hood pins, Pirelli P-Zero P255 40 ZR19 wheels mounted on 2014 Mustang GT Wheels
Badinuf is offline   Reply With Quote
Old 12-12-2010, 06:02 PM   #5
Re: Strange squeak
Sounds like a TOB problem. If it continues to get worst I would recommend replacing it.
Old 12-13-2010, 08:25 AM   #6
Re: Strange squeak
you can stop the noise a bit by self adjusting your clutch quadrant to take up a click or two of slack. This may/may not fix it (at least for a bit)
Old 12-21-2010, 04:19 AM   #7
Add another for throw out bearing
Old 12-21-2010, 09:25 PM   #8
So the only way to solve this problem is jus replacing it? I am having the same issue.
01 GT
BBK Cold Air Intake
BBk Headers
Steeda Short Shift
Flowmasters
Stage 2 clutch
01gt is offline   Reply With Quote
Old 12-22-2010, 12:42 PM   #9
04machazblue's Avatar
If u do decide to replace the throw
Out bearing make sure the retainer sleeve is not worn out Bc the retainer sleeve is part of the bell housing which is integrated which sucks if you do the bearing check everything cover your ***. I had to drop my trans twice in 3 days Bc the sleeve good luck
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 12-31-2010, 12:25 PM   #10
Re: Strange squeak
It's not the TOB I have a 2000 gt auto and it does the same thing it is actually the power steering pump it will make that noise until it worms up
cobragt2000 is offline   Reply With Quote
Engine Squeak bobby02V6 Pre-2005 V6 Mustang 3 11-27-2010 05:12 PM
Strut Squeak greenpony02 Pre-2005 V6 Mustang 14 03-09-2010 01:21 PM
A/C squeak Foxone General Mustang Discussion 9 11-22-2009 02:01 PM
body kit squeak Warfire80 Mustang Audio & Video 9 11-15-2005 11:20 PM
Rear Squeak....Please Help!!! drzeusd Pre-2005 V6 Mustang 3 10-20-2003 02:44 AM
02:52 AM
