Just changed plugs on 99 cobra, tubes filled with oil??!! - Mustang Evolution
Old 12-12-2010, 12:06 PM   #1
I just changed the spark plugs in my 99 cobra for the first time and almost all of the tubes were filled with oil!! some covering the spark plug all the way, some just covering half the plug. I used a rag and screwdriver to put in the hole before removing the plug so not as much would go in the motor, but obviously some did. I would start it after each plug install to burn out the oil. after they were all changed, it smoked for about 1/2 mile while it all burned out, then no more oil out the back. What is the cause of this? do i just need the valve cover gaskets replaced, or is it more serious?
disneyfun1 is offline   Reply With Quote
Old 12-12-2010, 12:25 PM   #2
MonteCitan's Avatar
Re: Just changed plugs on 99 cobra, tubes filled with oil??!!
As stated in your other post.. It is most likely (95% chance) that it is the valve cover gasket, as you'd suggested -
It's likely not more serious but it'd be a good idea to take care of it before you start seeing misfires due to oil shorting out the plug/ deteriorating the coil boots
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 12-12-2010, 12:28 PM   #3
Thanks, thats what i was thinking
Old 12-12-2010, 12:29 PM   #4
MonteCitan's Avatar
When I worked as a Ford tech, it was very common for all the 4V motors to do this.. and some of the 2V (oddly more in the crown vic than the other 4.6s..)
Old 12-13-2010, 12:10 PM   #5
Blustreek's Avatar
Region: Hawaii
Yeah I was familiar with ur problem.It happened to me w/my car.No,not a mustang or ford in general but a Nissan yes a'95
Nissan Maxima with the VQ30DE Twin cam motor.Neglect is a very
bad thing,You'll end up with a CHAINGANG of headaches that follow in sequence.So a big warning to u bro.Happy wrenching Disneyfun1!!
Blustreek is offline   Reply With Quote
Old 12-15-2010, 11:59 PM   #6
roger306's Avatar
Region: New Mexico
You need to replace the spark plug tube seals they come with the new gaskets get the felpro ones as there tube seals are a improvement over the stock ones
roger306 is offline   Reply With Quote
Old 12-16-2010, 04:56 AM   #7
How hard or easy is it to change them all out? I called my local shop and they want 4 hours to do them both, $310 with parts!
Old 12-16-2010, 07:30 AM   #8
the hard part is the side with the master cylinder, its the pain
Old 12-16-2010, 02:43 PM   #9
stampde's Avatar
yup spark plug tube seals ,and you gotta take the valve cover off to do them so you might as well do vc gaskets too .............. and YES the mast cyl side's a ***** !!!!
2011 GT Auto
Old 12-16-2010, 03:37 PM   #10
roger306's Avatar
Region: New Mexico
Try doing it on a Mach 1 got to remove hydro boost and master cylinder and then remove shaker, then heater hose on pass side , fuel line , throttle body. So make sure you get a gasket for the t-body to
When to change plugs on 99 cobra? disneyfun1 1996-2004 Mustang GT 8 12-13-2010 08:17 AM
oil on top of plugs jimmy_beaner 1996-2004 Mustang GT 14 05-13-2010 03:54 PM
Finally changed my plugs NorwegianMustang Pre-2005 V6 Mustang 3 07-18-2003 09:55 AM
04:52 PM
