Need help with tire sizes - Mustang Evolution
Old 12-19-2010, 09:10 AM   #1
I am currently looking at a set of rims for my 02 gt and want to keep the same tire diameter as my stock tires. I have 17s n want 18s. The rims I want for the front are 18\8.5 and the rear are 18\9.5. Can some one help me out or let me know what a good size would be for low profiles?
Myles is offline   Reply With Quote
Old 12-19-2010, 09:18 AM   #2
sick04mustang's Avatar
235/50/18 same overall diameter as stock 17's
04GT(BRANDI) VORTECH S/C,PATRIOT STAGE2 HEADS,ANDERSON POWERPIPE,SUPERCHIP,36IB INJECTORS,4.10, C&L INTAKE,ACCUFAB THROTTLEBODY, 1/2INCH INTAKE SPACER,EIBACH PRO SPRINGS,H.O.FIBERTRENDS 4INCH HOOD
sick04mustang is offline   Reply With Quote
Old 12-19-2010, 11:02 AM   #3
Re: Need help with tire sizes
I wouldn't do this.
This guy has bad info. That tire has 27.3" diameter compared to the stock 25.7" which will throw your speedo way off.. Check out tire rack you can see diameters
235 might be a stretch on a 8.5 wheel and surely would be a stretch on a 9.5 wheel and would look goofy. Also putting a skinnier tire than stock on a mustang is gay.
245/40/18 on front and 275/35/18 for the rear will be spot on matching the wheel width you selected and matching factory tire diameter keeping the speedo correct if you don't have a tuner to compensate
ajpturbo is offline   Reply With Quote
Old 12-19-2010, 11:31 AM   #4
Sry read to much into it.no they wont fit 9.5 but will 8.5 my bad and thank u for correcting me.
Old 12-19-2010, 06:42 PM   #5
Supersnake4.6's Avatar
You gonna want 245/ 45 / 18 for the front and 255/40/18 for the rear that's what I have on my car it it still look ls stock
Supersnake4.6 is offline   Reply With Quote
Old 12-19-2010, 08:09 PM   #6
Wrong again. Don't do that either.
The fronts are much taller than stock but the backs would be close.
You must get a close match to the oem diameter or else your speedo will be off unless you have a tuner to adjust it. Not too mention if you go to big you will rub.
stock diameter is 25.7". Try to stay with in 1/4" of that
Old 12-20-2010, 10:22 AM   #7
18x8.5 run a 265/35/18 or a 275/35/18
18x9.5 run a 295/35/18
Old 12-20-2010, 07:48 PM   #8
This would work but tire rack suggests a 10.5" wide wheel for a 295 tire but gives a range of 10"-11" and the 295/35/18 is about .4" taller than the stockers.
275 or 285 35 is better as far as staying close to stock diameter keeping your speedo accurate.
Sizes SVTCOBRA Mustang Wheels & Tires 5 03-29-2010 07:15 AM
Compare tire sizes, even for different size rims. Otlaw80 Mustang Wheels & Tires 4 06-15-2009 10:03 AM
Speaker Sizes? FloMasta24 Mustang Audio & Video 25 03-08-2005 11:00 PM
Tire Sizes for 18's Black95GT Mustang Wheels & Tires 16 04-04-2004 08:33 PM
Tire Sizes Laser02 Mustang Wheels & Tires 26 01-10-2004 12:22 AM
02:41 AM
