Gas ? - Mustang Evolution
Old 12-21-2010, 07:41 AM   #1
Loraco's Avatar
Send a message via Yahoo to Loraco
Gas ?
I use only premium gas in my GT, is there any thing else I should put in my gas tank to help keep the engine run clean and for better performance?
APRILS MOTM to drive is the reason the destination is just the excuse.
Loraco is offline   Reply With Quote
Old 12-21-2010, 07:46 AM   #2
Re: Gas ?
unless tuned for premium its a waste of money. The octane you need is based on the vehicles tune, if tuned for better gas (91 or 93) then of course use it.
I run fuel injection cleaner in it every oil change (the good stuff) thats about it. As said above unless tuned for higher octane or your gas is bad (87 isnt really 87) you wont see any performance gain from going to premium on your car.
Old 12-21-2010, 07:57 AM   #3
Well most regular and mid-grade fuels contain ethanol which has less btu thereby less power per drop. I have noticed mileage drops of at least 10% as compared to using shell v-power. And my car will sputter and idle roughly when using shell regular or mid-grade. Spector is correct that if your car isn't tuned for it the octane doesn't improve mileage however the fact that premium at most stations are ethanol absent that will improve your mileage. And believe it or not I have found that torko synthetic 2 stroke oil when mixed 1 ounce per 10 gallons improved my mileage by 2 mpg. I keep very accurate fuel stats. I have found that my car runs best on shell v-power but bc has chevron 94 octane ethanol free and that stuff is like rocket fuel in my mustang.
Old 12-21-2010, 08:02 AM   #4
I have also read in the gas savers forum that acetone can help mileage. I use seafoam every second oil change however to keep intake valves vacuum lines fuel system and crankcase free from build up and sludge. I heard about seafoam about a year ago and thought what the heck try it out. My trick has 300000 kms and after a seafoam treatment it ran like the day I rolled it off the lot. I swear by it now
Old 12-21-2010, 08:19 AM   #5
Loraco's Avatar
Thanks guys for the info I'm coming up on an oil change so that helps a lot!
Old 12-21-2010, 08:26 AM   #6
Re: Gas ?
seafoam is good stuff, they say not to use it on cars with root/twin screw blowers... but it might be fine in the fuel system vs intake system.
Old 12-21-2010, 08:31 AM   #7
I put it in crankcase about 1000kms before oil change to loosten up any gunk so it doesn't clog filter on new change
Old 12-21-2010, 12:33 PM   #8
junoS197Bl08's Avatar
Re: Gas ?
the only real difference in octane is the way that the fuel explodes, for instance 93 octane will explode more uniformly than 91, or 87. They test these in bomb calorimeters and in order to see how the fuel explodes. And scientifically speaking the energy difference is not significant and should not affect your fuel economy in a gas combustion engine, beyond that it will affect your gas mileage because our engines were not built at compression ratios for larger percent composition ethanol. You should not purchase gas at an octane above your tune b/c its just a waste of money
2008 V6 Windveil Blue with 5spd standard transmission-pony package, replica rims, shorty antenna
junoS197Bl08 is offline   Reply With Quote
Old 12-22-2010, 06:15 AM   #9
SaleenFiend's Avatar
Re: Gas ?
And becuase it detinates at an incorrect time in the combustion chamber which causes pinging among other problems. Higher Octanes serve no purpose on an improperly tuned vehicle.
Old 12-22-2010, 07:19 AM   #10
Re: Gas ?
also you cant mix five gallons of 87 and five gallons of 93 and get some higher than 87 value (not always) as it depends on the scotch value of the gas how it mixes.
Old 12-22-2010, 07:40 AM   #11
Re: Gas ?
hahaha that made my morning spec...ive never heard of somebody doin that but i guess that makes sense that somebody would try it haha
Old 12-22-2010, 08:01 AM   #12
Loraco's Avatar
Re: Gas ?
its not like I would have done it any way!! I dont even know what hes talkin about I never have worked on cars I'm a girl not sayin girls dont work on cars but just not this girl!
Old 12-22-2010, 08:40 AM   #13
Re: Gas ?
i don't think spec was insinuating you wouldn't know that cuz u were a girl but keep rockin it anyway
Old 12-22-2010, 11:18 AM   #14
Re: Gas ?
I know plenty of girls who work on cars... it brings their scale rating up a few points sometimes (you know, 1 to 10 ratings!)
Old 12-22-2010, 11:25 AM   #15
Re: Gas ?
I agree Saleen, ladies plus cars mix well, y do u think guys give their cars girl names
Old 12-22-2010, 11:38 AM   #16
Loraco's Avatar
Well I'm learning that's why Im here it sucks when people ask you about your car and your like daaahhh I don't know! If you going to drive a flashy car you need to know the answer or your just a dumb blond!
Old 12-22-2010, 01:03 PM   #17
Re: Gas ?
not making fun of anyone, just saying you cant mix gas grades, just an FYI kinda thing~ i mean some do its not going to destroy the car but it wont raise the octane like most think~ not in all cases.
07:10 AM
