HELP! Radio Wiring Problems - ODD One! - Mustang Evolution
Old 12-26-2010, 10:34 PM   #1
Here is a strange one. Have an 02 GT conv, automatic with all the bells and whistles including the Mach1000 stereo. The radio turns on while the shifter is in park and neutral, but when you put it in either R or any of the D 1,2...it turns completely off with the LCD display completely blank. It does this whether the engine is running or not. The shifter only has to partially leave the P or the N, but does not have to engage the gear. It does it reliably, not intermittently. I don't think it is a ground issue, as when the radio does come back on, it still has all of it's memory and is on the same radio station and time is correct. It did this once before about a yr ago. I took the dash and radio wiring all apart and never found anything obvious, but when I put it back together, the problem disappeared...not sure if it was one of the connectors or just coincidence that it fixed itself. I was just glad I had tunes again.
BUT, what the heck does the shifter have to do with anything? the only thing I can think of is maybe the reverse lighting circuit, or the convertible top switch circuit (car has to be in neutral with pk brake on to work the top). No wiring is close to the shifter, so I am at a loss as to why this is happening....Help me Mr Wizard!
gambler669 is offline   Reply With Quote
Old 12-26-2010, 10:51 PM   #2
Re: HELP! Radio Wiring Problems - ODD One!
Maybe the Overdrive button? I have seen the Overdrive button and cigarette lighter cause problems with one another. Weird problem though, sorry I don't have more input
Old 12-27-2010, 07:56 AM   #3
A.K.A. Baby-D!
is it an aftermarket stereo deck or still the stock Mach one?
if its an aftermarket and has any video capability, i've seen some of those do this as a safety feature... so you can't watch video as you drive. but i'm sure there is a wire you can disconnect or bypass with a toggle switch if thats the case.
Current:
1989 GT--the project
Previous:
2004 V6--my first pony
1988 GT--July 2010 MOTM
odd problem 95YellowGT_5.0 1979-1995 Mustang GT 3 08-03-2010 01:29 PM
05 Mustang V6 Windshield and Radio Problems! CBurn 2005-2010 Mustang GT 2 07-15-2010 11:07 PM
2000 Mustang V6 Wiring Door panel wiring problem wyatt-00' Pre-2005 V6 Mustang 3 11-30-2009 12:43 AM
this is very odd!! I'm hurt V6STANG007 The Bar 5 07-14-2006 10:37 AM
Odd request. Monkey The Bar 7 09-15-2003 09:14 PM
05:58 AM
