Gas peddle or throttle sticking - Mustang Evolution
Old 01-02-2011, 07:47 AM   #1
Can anyone tell me what would cause my throttle or gas peddle to stick? When I'm driving it's fine but from a dead stop taking off I have to apply more pressure to the peddle than I should to get the peddle to give but once it gives it's fine until I take my foot all the way off the peddle..
Myles is offline   Reply With Quote
Old 01-02-2011, 09:36 AM   #2
You might to check in the throttle body. Some times the carbon builds up enough to make that happen so I have heard anyway.
Faststang0485 is offline   Reply With Quote
Old 01-03-2011, 04:25 AM   #3
Re: Gas peddle or throttle sticking
It's a brand new throttle body
Old 01-03-2011, 05:02 AM   #4
Check and make sure you have the throttle adjusting screw set to where it needs to be, like with just a little tenstion on the throttle. My screw was turned almost out and it would do the same thing.
Other than that spray some lube on the linkage and hope for the best.
Straublittleman is offline   Reply With Quote
Old 01-03-2011, 06:02 AM   #5
Clean the throttle body with brake fluid cleaner and that should work
01slwgt is offline   Reply With Quote
Old 01-03-2011, 06:12 AM   #6
Nooooooooi don't ... Your throttle body has a coating on it to keep it from corroding. Brake fluid will take that coating right off,so will carb cleaner. Use seafoam to clean intake components. And your throttle body isn't drive by wire it is computer controled. If the tb is brand new that throttle screw MIGHT be out too much but if you have a tuner that will cure it with no tools
Old 01-03-2011, 06:34 AM   #7
You could try carburetor cleaner to clean the throttle plate inside the throttle body
Paul0796 is offline   Reply With Quote
Old 01-03-2011, 07:04 AM   #8
if all that fails it could just be the cable itself, but its probably something to do with the throttle body
Old 01-05-2011, 05:01 PM   #9
I hae heard that some throttlebodies can be sticky. Which t-body are you running?
i973eat1 is offline   Reply With Quote
Old 01-07-2011, 02:16 PM   #10
what year is it? anything older than 04 is fly by wire. and do not use carb or brake cleaner on it.. not to mention the "protective coating" and if you've got a stock intake.. ie the plastic one.. you could run the risk of cracking it because it has a similar effect as nitrous..
jdwasher42 is offline   Reply With Quote
Old 01-07-2011, 07:57 PM   #11
Any older than an 04 is is driven by cables not fly by wire they put that stupid crap in 05 and newer and I heard seafoam if not done properly will cause serious issues so better to take the throttle body off and use a product cal CRC throttle body cleaner yes amazing a product designed just for that. If you clean it lube the cable with good old PB blaster and I agree with checking the throttle adjusting screws just to make sure that is if it's an 04 or older.
Old 01-08-2011, 07:08 AM   #12
its a bbk 75mm
Old 01-10-2011, 02:37 AM   #13
Well, I know what not to get. Lol
98GT- CAI,Steeda Tri-Ax,o/r H, Underdrives, toon, more to come!
94V6- CAI, true duals, underdrives. the playtoy
Old 01-10-2011, 07:20 AM   #14
Ya thane for being a smart@$$, clown
Old 01-10-2011, 06:26 PM   #15
well, pull it off! check to see where it is sticking at! get out and figure it out.. hell i took sandpaper to my v6 t-body, and sanded it down for better airflow, then coated it w/ WD-40, and NEVER had a problem.
I started another thread asking people what their favoritte t-bodies are, and one guy said that his BBK did the exact same thing that you are describing.
Idle sticking Rascal Pre-2005 V6 Mustang 2 08-11-2010 02:18 PM
Cruise Control Sticking meteorachick Pre-2005 V6 Mustang 19 06-19-2008 05:39 PM
Clutch sticking to Pressure Plate??? Rick0636 Pre-2005 V6 Mustang 5 11-08-2003 06:28 PM
04:19 AM
