Custom tunes question. - Mustang Evolution
Old 01-03-2011, 06:31 AM   #1
04silverpony's Avatar
Send a message via AIM to 04silverpony
Would I see any noticeable improvements with a custom tune? Only engine mods are CAI , cat-less exhaust? Or should I spend $$ on more mods before changing from stock tune?
04silverpony is offline   Reply With Quote
Old 01-03-2011, 07:05 AM   #2
Re: Custom tunes question.
a tune will help, it seems 96-04 pick up between 10-15rwhp depending on how good the tune is and what modifications are done. I would personally get all the bolt ons then tune it. The key to a tune is who does it, you cant just buy an SCT tuner and use the off the shelf tune and be done with it as thats not nearly the optimal tune for the car. There are probably many really good tuners in your area that can help you out~ just got to find them.
Old 01-03-2011, 01:03 PM   #3
stampde's Avatar
FUNNY MY 03 Mach 1 saw 24 rwhp with a dyno tune
2011 GT Auto
Old 01-03-2011, 01:16 PM   #4
its a mach 1 (different heads, and other stuff) not a 2v GT and it also depends on many factors~ on average you dont get a ton from a tune. Mine picked up quite a bit but thats just how my car is also.
Old 01-03-2011, 01:19 PM   #5
stampde's Avatar
and my Buddy did the tune , he knows a lot of things to do to get more power ,like turning off the knock sensor so we could get more timing etc ..........
2011 GT Auto
Old 01-03-2011, 02:04 PM   #6
I have no knock sensor I wish I did
Old 01-04-2011, 12:10 AM   #7
LSUstang's Avatar
Send a message via AIM to LSUstang
what is a knock sensor?
-2004 Mach 1 "Natasha"- JL Audio W6 w/ custom box, 8000K HIDs, Sequential signals, StangHi tune, Borla Stingers with catted X, deck lid & lower valence, C&L intake package, H&R Super Sports
-2001 White Vert V6- Sold
LSUstang is offline   Reply With Quote
Old 01-04-2011, 12:15 AM   #8
A knock sensor is in your motor. Is senses spark knock and will ****** timing til the knock is neutralized. It's a safety feature in case you get crappy gas
Old 01-04-2011, 12:16 AM   #9
Yes you will see an improvement from a custom tune. Ford sends cars out with a conservative tune so they don't push the envelope.
Old 01-04-2011, 12:18 AM   #10
LSUstang's Avatar
I wonder if Stang-Hi in Baton Rouge turns of the knock sensor? I should go to them and tell them to UNLOCK my X3 Tuner! For some reason he locked it so I would have to come back to him.
Old 01-04-2011, 12:38 AM   #11
What year is your car. I don't think the 99-04 2v has a knock sensor. I will have to check my haynes manual when I get home.
Old 01-04-2011, 12:39 AM   #12
Bad idea.... Knock sensor is very important
Old 01-04-2011, 12:39 AM   #13
LSUstang's Avatar
2004 mach 4V
Old 01-04-2011, 12:56 AM   #14
The 2vs don't have em but the 4vs do.
Old 01-04-2011, 01:00 AM   #15
2004 mach 4V
You would likely get another 20ish hp from a custom tune.
Old 01-04-2011, 01:21 AM   #16
LSUstang's Avatar
Already have a tune. Don't have a clue what HP gain since it wasn't dynotuned
Old 01-04-2011, 07:28 AM   #17
a tune that was not dyno'ed to check is probably not a very good one, or at least not one that is the best it can be. Its always best to get a tune either done while its being dynoed or get a tune in the mail and verity it on a dyno for saftey and send the data logs back to the tuner to update and repeat until happy. Thats the fun process I had to go through
the 03/04 4v cobras dont have knock sensors so its VERY important they are tuned right with no detonation. I had a little when I first got my tune that I found out was bad gas then I had a little under light load going WOT that I had to get fixed via data logging/ dyno and tune updates.
Kenne Bell tunes GOOD or BAD ????? Cobra GT 1996-2004 Mustang GT 3 11-12-2010 01:01 PM
VMP Tunes the 07 Shelby GT500...505 RWHP justin00stang General Mustang Discussion 9 09-18-2006 10:03 PM
08:24 PM
