exhaust 0/2 sensor elimenators, are they need? - Mustang Evolution
Old 07-12-2007, 04:30 PM   #1
Hey, I have a 96 GT and just had the local exhaust shop run full dual exhaust for me. no X or H pipe, but got rid of the cats and added 2 4o series flowmasters. If I dont buy eliminators can it cause my car to run crappy. My car seems to run great for a while but I have a hour drive to and from work each night and live in south florida, and by the time I get home it feels like im pulling a boat.
could this be because my o/2 arent hooked up anymore? Do the eliminators just help with the check engine light?
My car just seems to have good day and bad ones....I appricate any help.
rob4292 is offline   Reply With Quote
Old 07-19-2007, 03:16 PM   #2
Re: exhaust 0/2 sensor elimenators, are they need?
Yes is will but do you have SCT programer?
Maxion$mulla$ is offline   Reply With Quote
Old 07-23-2007, 06:44 PM   #3
hottcobra's Avatar
yes you need to get a tune or MILs and why no H or X pipe
Old 07-23-2007, 08:32 PM   #4
bbunt302's Avatar
The no H or X-pipe was a mistake. The pipes cross over for a reason.
All 90* V8s have an imbalance in firing order which results in two cylinders on the same bank firing almost simultaneously every couple of crank turns. This means they are both trying to dump exhaust into the same header at nearly the same time. By having a crossover pipe, some of the air is allowed to move over to the other pipe for an even distribution. You've essentially killed this ability.
I would recommend you buy some MIL eliminators and throw a good midpipe on there (I personally like the MAC Pro-Chamber).
Scary stuff.
Old 07-23-2007, 08:41 PM   #5
Y2E0L0L5OGWT's Avatar
Not to mention the fact that you should have some form of crossover for motor safety...someone could easily put a potato or something in your tailpipe, and well, without a crossover, you could be having a bad day...
Old 07-30-2007, 04:26 PM   #6
I know I should have dont some sort of crossover, but damm just to run the exhaust like I did was $450, would have been up wards of $700 for a cross over. I couldnt justify the money on a car I dont really race, just use as a work car and cruise with. I thought the X pipe was mainly for horse power and didnt think spending an extra $250 (with welded install) was worth it. Maybe I was wrong. I will try and get the Mils. I appricare eveyones advice.
Old 07-30-2007, 04:28 PM   #7
Send a message via MSN to 1996stang Send a message via Yahoo to 1996stang
I got my offroad h pipe for $169 its a bolt on took 15 min on a lift.The catback bolt's right too it.My full exhaust mid pipe back was only $300
2004 mach 1 stock and staying that way.
1996stang is offline   Reply With Quote
Old 04-14-2008, 09:03 PM   #8
dude i got my x pipe for about the same as the other guy and mils are like 60 bucks and it takes like 15 mins on a lift i dont understand the logic behind that you didnt do any research?
giddyupgt is offline   Reply With Quote
Old 04-17-2008, 09:47 AM   #9
1234's Avatar
Youve gotta give some props to the people that design the cars and the aftermarket parts for them. so if nobody makes it, it probably isnt worth a **** or a very good idea to install it without some research.
exhaust
O2 SENSOR redGT773 2005-2010 Mustang GT 21 01-29-2009 01:17 PM
M.A.F. Sensor 03GTNEWB 1996-2004 Mustang GT 5 07-15-2008 11:45 AM
o2 sensor Mustang414 Pre-2005 V6 Mustang 0 05-18-2005 08:36 PM
O2 Sensor Out. Dom Pre-2005 V6 Mustang 18 12-18-2004 07:58 PM
IAT Sensor Gitanos_Stang Pre-2005 V6 Mustang 2 05-29-2004 08:19 AM
08:52 AM
