96 cobra engine ticking please help!!!! - Mustang Evolution
Old 01-03-2011, 10:39 PM   #1
Exclamation 96 cobra engine ticking please help!!!!
I have recently done an engine swap on my 96 cobra. When I first started the engine it ran great with no noises but a ticking noise started. The ticking is only at idle and goes away around 1200 rpm. When the engine warms up it goes away completely. I'm thinking its the lash adjusters but I'm not sure. Looking for ideas.
proberts is offline   Reply With Quote
Old 01-03-2011, 10:42 PM   #2
Try thicker oil. If you are using mobil one I have heard that it causes ticking in 4v motors but have no first hand knowledge.
Old 01-04-2011, 07:38 AM   #3
Re: 96 cobra engine ticking please help!!!!
try to isolate the noise so you are sure its not injector pulses vs a knock or the heads
Old 01-04-2011, 09:21 AM   #4
Thanks its at inspection right now ill have them change the oil. Its running Quaker State 10W-30 right now. We have pretty much determined its coming from the head so I will see if that helps.
Old 01-04-2011, 10:10 AM   #5
sometimes the timing chains have issues with the little tension adjusters not sure it makes a tick.
Exhaust leak/ticking. Possible EGR Valve? amowry01V6 Pre-2005 V6 Mustang 0 09-10-2008 07:25 AM
ticking/ knocking sound almostxevil Pre-2005 V6 Mustang 16 04-04-2007 06:29 PM
1994 cobra engine f/s mpsstang Mustang Parts for Sale and Wanted 11 01-28-2006 07:34 AM
Ticking noise in the engine.... eNvy Pre-2005 V6 Mustang 11 05-09-2004 11:41 AM
95 cobra engine whipster24 Pre-2005 V6 Mustang 2 11-26-2003 05:22 PM
08:38 AM
