Rear rotors on an 02, cant get them off - Mustang Evolution
Old 01-04-2011, 02:53 AM   #1
Unless I'm being retarded it looks like I need a special tool to take my rear roaders off on an 02.
Myles is offline   Reply With Quote
Old 01-04-2011, 05:47 AM   #2
re: Rear rotors on an 02, cant get them off
What the hell is a rear roader? But yeah you do need a special tool for the job. The one I used is a square that attaches to a socket. You need it to take the calipers off right?
tigerfan2771 is offline   Reply With Quote
Old 01-04-2011, 06:41 AM   #3
SVTCOBRA's Avatar
Cool re: Rear rotors on an 02, cant get them off
Unless I'm being retarded it looks like I need a special tool to take my rear rottors off on an 02.
fixed it for you.
A Super Torque Ford!
"The problem with socialism is that eventually you run out of other people's money." (Margaret Thatcher)
SVTCOBRA is offline   Reply With Quote
Old 01-04-2011, 07:20 AM   #4
you will probably need a special tool to compress the piston in the caliper to reinstall it as it screws in instead of simply sliding as the fronts do. Other than that its two bolts to remove the factory caliper then the rotor pops right off. Some cars have OEM rotors that have never been removed, those will have little metal rings around a couple of so of the wheel studs that you simply pull off. If its rusted on tap it with a hammer to pop it off. Use correct torque specifications on re installation of the rear caliper.
Old 01-04-2011, 09:47 AM   #5
Loc: Austin,TX
Originally Posted by SVTCOBRA View Post
fixed it for you.
What's a "rottor"?
Old 01-04-2011, 11:13 AM   #6
SVTCOBRA's Avatar
Re: Rear rotors on an 02, cant get them off
Originally Posted by DDTCM View Post
What's a "rottor"?
ops I'm using my new HTC phone and I must have hit the t twice
Old 01-04-2011, 11:16 AM   #7
What's a "rottor"?
Lol. I didn't wanna be a dick twice
Old 01-04-2011, 12:09 PM   #8
Loc: Austin,TX
I got your back homes .....lol. My HTC does that sometimes to.
Old 01-04-2011, 12:26 PM   #9
ibleedblue65's Avatar
The special tool you need is called a bfh.
ibleedblue65 is offline   Reply With Quote
Old 01-04-2011, 12:51 PM   #10
04machazblue's Avatar
Big ****ing Hammer lol
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 01-04-2011, 05:37 PM   #11
SVTCOBRA's Avatar
my fingers are too big for the touch screen
Rotors electricstang Pre-2005 V6 Mustang 7 05-10-2006 07:38 AM
Rotors going bad? MustangChick88 Pre-2005 V6 Mustang 12 11-22-2005 08:42 PM
Rotors Matt'sredbeauty Pre-2005 V6 Mustang 7 11-11-2005 09:11 PM
Brembo Sport Slotted Rotors (Rear) Hawk Pads mattstang Mustang Parts for Sale and Wanted 7 04-30-2004 07:08 PM
07:13 PM
