lowering suspension kit - Mustang Evolution
Old 01-08-2011, 07:06 AM   #1
im looking at a B&G lowering kit it drops both front and back 1.75 in and i was wondering if i need camber and caster plates or if i can get buy without them?
Myles is offline   Reply With Quote
Old 01-08-2011, 07:55 AM   #2
When even you lower a mustangs lower than an inch you have the plates it sucks nuts but the stock plates just don't have any adjustment I am in the same point lowering my car but don't want to $200 for a set.
Faststang0485 is offline   Reply With Quote
Old 01-08-2011, 08:29 AM   #3
Re: lowering suspension kit
someone was telling me that you can grind out the stock plates a little bit for the adjustments. i was also told you might not need the plates unless you drop it more than 2 inches
Old 01-08-2011, 08:35 AM   #4
I guess you could but grinding on plates just doesn't sound safe. But your car. I got a buddy with a 95 5.0 and he lower the front an inch 1/2 and his **** is off by like -5 degrees but its whatever good luck on that
Old 01-08-2011, 09:41 AM   #5
Loc: Austin,TX
A 1.5 is not gonna effect it that bad but a 1.75 will. Look into some camber bolts,you can find them for around $30 give or take.
Old 01-09-2011, 08:17 AM   #6
why would i buy just camber bolts? what is that gonna do for me?
Old 01-09-2011, 11:33 AM   #7
drusmith's Avatar
Send a message via Yahoo to drusmith
I just installed the Caster Camber plates this weekend on my terminator while H&R SS lowering spring install. SO EASY! Just do it, its worth the $180. Makes everything down the road easier to adjust. They look cool to!
drusmith is offline   Reply With Quote
Old 01-10-2011, 09:56 AM   #8
there are "ways" to adjust the camber with out adjustable caster/camber plates... but generally the best and safest way is a nice set of good quality caster/camber plates. The only ones I would recommend are maximum motorsports for many reasons.
The stock ones have NO adjustment on most all 94+ mustangs
Old 01-11-2011, 07:59 PM   #9
Titus Wadicus
svtlx's Avatar
my alignment guy drilled out the rivets on the shock tower to give room for the adjustment. should be ok if u stay under 2inchs. im get'n ready to do my 97 now
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-12-2011, 07:31 AM   #10
the 94+ ones ive seen the bolts on the stock bolt holes that hold on caster/camber plates have no adjustment they are just round so you cant slide them anywhere. You can look up underneath the car into the strut tower and see if you have adjustment perhaps~ that hole can technically be made into an oval for adjustment if you wanted~
Old 01-12-2011, 09:31 AM   #11
Titus Wadicus
svtlx's Avatar
i guesse ill compare my 97 to my 92 and c how similar they are, or add my own slots like u said. my grinder is my best friend...lol
Old 01-12-2011, 11:03 AM   #12
my 01 didnt have them but my 03 cobra has a slot~ its odd. You can also get the wobble bolts for the bottom where the strut goes to the spindle/knuckle~
If you ever plan coil overs mm cc plates are the only way to go
Old 01-12-2011, 11:26 AM   #13
Titus Wadicus
svtlx's Avatar
im too cheap for that. springs and a front end alighnment will probably do it for me. i just want it stable for high speed straight from time to time. im not a true corner carver or slalom course driver. ill probably only g0 1.5-1.7 in the front anyway, unless i score another awsome deal on some vogtlands. im tryn to find some inexpensive specific rate springs. all the manufactures primarily sell progressive. my car is super loud, so i dont mind if it rides like a brick ..lol
Old 01-12-2011, 11:43 AM   #14
drusmith's Avatar
If you are looking for cheap try:
MRT
(734) 455-5807
45646 Port St
Plymouth, MI 48170
I picked up my springs for $189.99 shipped. Where in Ohio are you?
Aftermarket Performance Parts for Mustang, Camaro, Fusion, Truck - MRT Direct
Old 01-12-2011, 11:52 AM   #15
Titus Wadicus
svtlx's Avatar
columbus...home of jeg's!!!
Old 01-12-2011, 12:03 PM   #16
drusmith's Avatar
I was just in Columbus last week on business. Also home of the F*cking Buckeyes! GO BLUE!!!
Well I hope we can put together a Midwest car show or something so we can all meet other members that or in the area.
Old 01-12-2011, 12:16 PM   #17
Titus Wadicus
svtlx's Avatar
that sounds like all kinds of fantastic. let me know wut i can do. there's alota stangers here, but not alota stang unity. two much competion amongst each other in da ford camp. it keeps ppl devided and not exchanging numbers except for small cliques. i can try to hook up with columbus racing clique. it's a big organization (group of street racers). i quit hangs wit them as much cause i value my drivers license. underground street racing is super huge here in columbus. im not sure y, as in 80-110 cars show up on a good night
Old 01-12-2011, 12:28 PM   #18
drusmith's Avatar
OMG, that sounds awesome! But your right! I value my DL way too much. reminds me back when I was younger and had my crouch Rocket. WE usually had 30-50 cars show up. Cops always bustin it up though.
My good friend has a Torch red 04 Terminator (stage 1 mods), and 2 other friends have 98 cobras with Turbos. its pretty fun! We love to drive place to place and chat and meet new people! Then I have a friend that works at ZZP ZZPerformance so there are always these Grand Prixs that want to race and I pass cause really no reason to beat up on a V6 lol.
Old 01-12-2011, 12:56 PM   #19
Titus Wadicus
svtlx's Avatar
shhh...dont type so loud. the v6 forum is next door. ive been read'n that they put as money in their motors as we do yielding half the horsepower
Old 01-12-2011, 01:00 PM   #20
drusmith's Avatar
THAT IS F*cking HILARIOUS!!!! It is a waste of $. Just buy V8.
Mustang = muscle car
V6 = Not muscle car
Old 01-12-2011, 01:08 PM   #21
Titus Wadicus
svtlx's Avatar
V6 = Not muscle car
you can get 4-600hp outa a 3.8 but u gotta throw soooo much boost at it your head will spin. if u dont snap a piston in half first. i saw a 500hp 3.8 but they were thrown like 19-22lbs at it, with an intercooler. im like you, just drop a v8 in it.
Old 01-12-2011, 02:00 PM   #22
there used to be someone that would post on here with a 700rwhp 4.2L stroked 3.8L v6 motor with like 25psi.... but 25psi on an 03 cobra = about the same rwhp... but he was turboed.
Old 01-12-2011, 02:16 PM   #23
drusmith's Avatar
Oh I know personally about the 3.8 engine. Just look at my SSEI garage on my profile page! 300fwhp. Car is heavy but it keeps up with most stock V8 Camaros and Mustangs that are 2000 or older! Even beats some!
Old 01-12-2011, 02:34 PM   #24
Titus Wadicus
svtlx's Avatar
im plan'n on moving up tp 14psi on my set up. im currently runn'n 11. im tryn to do sum more research on my blower. they sell a 20% flow upgrade impellor. but it's like 500bucks. i'd like to just change the pulley, but i been read'n stuff bout impellars breakn if over spun. my blower has all latest updats, im not sure wut to believe
Old 01-12-2011, 02:50 PM   #25
drusmith's Avatar
I wouldn't go smaller pulley! Seems lots of thing go wrong when people do that on any car. Right now I have about 16PSI running on my SSEI and 20PSI on the Cobra. I love boost, but there is such and thing as too much for what you have! Your PowerDyne is a bit different.
Old 01-12-2011, 02:54 PM   #26
Titus Wadicus
svtlx's Avatar
the 11 im running is already an ovedrive. my friend is running 12 on his. i already got the kevlar belt and the ceramic bearings. the safe route would be just change the impellar. idk....
Old 01-12-2011, 02:55 PM   #27
Titus Wadicus
svtlx's Avatar
11 to 14 isnt a huge jump. ill just fee better running a full atmoshere
Old 01-12-2011, 02:56 PM   #28
drusmith's Avatar
I am guessing your ride is something like this!!!!
Old 01-12-2011, 03:06 PM   #29
Titus Wadicus
svtlx's Avatar
i couldnt acces the link for sum reason..
Old 01-13-2011, 09:32 AM   #30
drusmith's Avatar
Try this! its the 8th video down.
mustang powerdyne 5.0 - Google Search
Old 01-13-2011, 10:21 AM   #31
Titus Wadicus
svtlx's Avatar
the convertible wit the broke tail light..yea. i got an auto and i can spin them halfway through 3rd if i manual shift and flash the converter on launch. that stang on the video was pretty mean.
Old 01-13-2011, 10:44 AM   #32
drusmith's Avatar
I thought you might like that! LOL
Old 01-13-2011, 11:23 AM   #33
Titus Wadicus
svtlx's Avatar
im still drooln over yours though...omg...
Old 01-13-2011, 12:45 PM   #34
drusmith's Avatar
Thanks man! We will have to meet this summer!
Old 01-13-2011, 01:05 PM   #35
Titus Wadicus
svtlx's Avatar
u bet, hopefully by then i will hvae transfered everything from my 92 to my 97
« Hard Launch Kit | Just got a fast mustang.. »
Lowering Kit racefan966 Pre-2005 V6 Mustang 2 09-15-2010 01:10 PM
WTB: Lowering Kit and Cobra Fogs... 94Stang504 Mustang Parts for Sale and Wanted 39 08-01-2008 12:01 PM
lowering kit? lowering kit 1996-2004 Mustang GT 11 07-19-2007 03:14 PM
Might have a lowering kit for edges soon!! sonic04edge The Bar 62 01-31-2005 02:06 PM
» Members Mustangs
2008 Ford Mustang GT
Jimmy joe
2013 Ford 5.0
TommyV
Add your Mustang
» Recent Discussions
06:33 AM
