Hard Launch Kit - Mustang Evolution
Old 01-11-2011, 10:18 AM   #1
drusmith's Avatar
Send a message via Yahoo to drusmith
Hard Launch Kit
Has anyone installed this hard Launch kit? Is it easy to install?
drusmith is offline   Reply With Quote
Old 01-11-2011, 12:50 PM   #2
Re: Hard Launch Kit
03/04 cobras have a HD cross bar from the factory, where the 99/01 cobras did not. If you want to launch hard you need to drop the IRS install all of fulltiltboogie's items and such or go wtih a solid rear axle.
Old 01-11-2011, 01:53 PM   #3
drusmith's Avatar
Re: Hard Launch Kit
So I need to do all this crap! damn!
dfsg
Old 01-11-2011, 03:41 PM   #4
Re: Hard Launch Kit
that hard launch brace might be even stronger than the upgraded one on 03/04's not sure
Old 01-11-2011, 06:31 PM   #5
Re: Hard Launch Kit
Hi...yes, i have installed this on my 04 cobra...yes, it does help!!!...and fairly easy to put on with a lift....is this the unit from rpm?
CobraTom is offline   Reply With Quote
Old 01-11-2011, 08:48 PM   #6
Titus Wadicus
svtlx's Avatar
Re: Hard Launch Kit
are the cobra irs's that flimsy. i beatn my 7.5 with a blower for several years now. i had a 5liter tbird with irs and it never broke either, i had it sideways everytime i gotta chance. im just curious. maybe i should get one...lol
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-12-2011, 08:17 AM   #7
Talking Re: Hard Launch Kit
Hi, lets put it this way...it is alot stronger than the stock!...But I cannot still get mine to put all of the power to the wheels anyways!!!!...typical stangs!!!!...gotta love em!...
04 cobra...whipple setup, 9 lb crank, 21 lbs boost, allkinds of other goodies...My passion IS Speed!!!!
Old 01-12-2011, 08:32 AM   #8
Re: Hard Launch Kit
the IRS just has a lot of rubber mainly. The extra braces are to keep it together from all the shaking and binding that takes place due to all that crappy rubber having issues.
Its an amazing setup with nice bushings and such
Old 01-12-2011, 10:40 AM   #9
Titus Wadicus
svtlx's Avatar
Re: Hard Launch Kit
o...ok, i c. i just know i loved it in my tbirds. v8 power, but handles and drives like a front wheel drive. that whole drive system was ahead of it's time and under appreciated.
anyway, so im guessing you get lotsa wheel hop with the irs set-up? i may have been putting down 300 at the crank wit my bird, so i know it's no comparison to 500 at the wheel. i just thought it may be a good swap since they are plentiful, everyone hates them and are getn rid of them. not to mention i dont race my car, ive never owned a set of d.o.t.'s or slicks.
also, wut's the ratio from the factory for the irs?
Old 01-12-2011, 12:01 PM   #10
Re: Hard Launch Kit
the 03/04 cobras have 3.55 gears in an alum chunk (not cast iron).
stock they wheel hop, some worse than others. Verts tend to be the leader in this with the extra flex they offer.
Now that I have lowered mine and have stiffer springs with wider tires its much better, it would still do it at the track I bet though.
For about 600-800 bucks you can do some great things to it though, ive seen one put in a fox before
Old 01-12-2011, 12:10 PM   #11
drusmith's Avatar
Re: Hard Launch Kit
CobraTom, Yes this unit is from RPM. Do you spend some time at the 1/4 mile drags? Ultimately I will be going to drags about 2 to 3 times a year.
Old 01-12-2011, 12:14 PM   #12
drusmith's Avatar
Re: Hard Launch Kit
hey thanks for your input!!! Yes I have some wheel hop and I have 597rwhp so its can be pretty intense to take off sometimes. Are you suggesting getting rid of IRS? I dont know if I want to do that.
Old 01-12-2011, 12:21 PM   #13
drusmith's Avatar
Re: Hard Launch Kit
OK guys, I think i might try the launch kit first to see if that helps. i also am in the middle of installing the H&R ss springs (front done, this Saturday do rear). So I think I will see how it is after that is done! Then maybe send it over to Full tilt boogie and spend the $600-800 that SpectorV had mentioned.
CobraTom, let me know what the difference was in your Terminator! Was it night and day difference?
Thanks
Old 01-12-2011, 12:51 PM   #14
Titus Wadicus
svtlx's Avatar
Re: Hard Launch Kit
no, no..i wasnt suggesting you get rid of it. i meant i was think'n of get'n one cause noone wants them. i know a guy who had 3 layn around his shop that he had converted for costomers that didnt want irs anymore. i personaly love irs. but im tryn to hit 500rwhp by the end of the summer, and maybe irs isnt the way to go. i got 453 at the wheels..boxed upper and lowers wit spherical axle bushings. wit a 2700 stall. and things can get real interesting if i dont watch myself. the wheels stay on the ground, but it spins like crazy. they use 7.5 irs for 5-600hp miata conversions all the time. so i figured i would be ok with an 8.8. irs. like i said, i was impressed the way my tbirds put the power down. but i will leave my 7.5 in rather than have worse traction issues wth an irs.
also, u never told me irs gear ratio
Old 01-12-2011, 01:06 PM   #15
drusmith's Avatar
Re: Hard Launch Kit
the 03/04 cobras have 3.55 gears. Sorry missed this post at first!
Old 01-12-2011, 01:19 PM   #16
Titus Wadicus
svtlx's Avatar
Re: Hard Launch Kit
hmmm. gears r grind'n n my head.
Old 01-12-2011, 01:21 PM   #17
Titus Wadicus
svtlx's Avatar
Re: Hard Launch Kit
i wanna go 4 a ride in your car. all my friends like riding in mine, but 600 at the wheels seems awsome!!!!
Old 01-12-2011, 01:32 PM   #18
drusmith's Avatar
Re: Hard Launch Kit
No problem! I love giving rides to true Mustang enthusiasts. 600hp is almost ridiculous. Its hard to keep traction at the start. Highway though, I can break your neck. Its awesome!
Old 01-12-2011, 01:45 PM   #19
Titus Wadicus
svtlx's Avatar
Re: Hard Launch Kit
omg...i gotta change my under wear in my car every once and a while. i cant wait. my friends dad had 600 at the wheels, and it would go sideways at 85. mine will do it at 50, so im getn close...sorta...lol. i got mostly stock stuff though.
Old 01-12-2011, 01:54 PM   #20
drusmith's Avatar
Re: Hard Launch Kit
Mostly stock stuff?
Old 01-12-2011, 02:02 PM   #21
Titus Wadicus
svtlx's Avatar
Re: Hard Launch Kit
Mostly stock stuff?
i mean yea, standard stroke..stock block, crank and heads. arp head studs and arp rod bolts. besides for bolt on stuff its fairly stock. i even run the stock 7.5 4cyl rear end. and still rockn the 4cyl brakes (micro rotors). the rest is all bolt on.
i dont listen to all those guys talkn bout dropn 1500 in the block before u even get to the good stuff. ford components are resileant, im proof of it.
Old 01-12-2011, 03:11 PM   #22
drusmith's Avatar
Re: Hard Launch Kit
Oh hell yey! Love Ford with a passion! The only reason I bought the SSEI is because it was a deal and I can make it go fast cheap!
Old 01-12-2011, 03:25 PM   #23
Have you been to the track yet? What does it run? What do you want to run? You may be able to turn the numbers with a set of good tires. With the wrong tires, suspension won't help much.
Alscobra is offline   Reply With Quote
Old 01-12-2011, 03:44 PM   #24
drusmith's Avatar
Re: Hard Launch Kit
I have not run mine yet. Just go it last fall. It has spent more time in storage then out cruisin. I would guess with the set up before was mid 11s. I want to get in the 10s. I really got to get some more wheel time. With this much HP it could run low 10s. Just got to get the HP to the ground.
Old 01-12-2011, 03:49 PM   #25
Re: Hard Launch Kit
if you plan to run 10s or that is your goal drop the IRS and upgrade all of the bushings etc etc or put a SRA in lol, dont break a half shaft or two to figure it out
Old 01-12-2011, 03:50 PM   #26
Titus Wadicus
svtlx's Avatar
Re: Hard Launch Kit
i got a 95 caprice lowered 2inch's..it's my other baby
ID:	22743   Click image for larger version
Old 01-12-2011, 03:50 PM   #27
11's Is not too bad. Slicks will get you there. To get into 10's, you will have to drive the **** out of it. I got 574 at the wheels and 11.50 is what I'm shooting for driving straight to the track. Have tranny problems right now but 11.5 should be no prob.
Old 01-12-2011, 03:54 PM   #28
drusmith's Avatar
Re: Hard Launch Kit
Check it out guys! I dont know if this is true or what be it seems to be. This dude can drive though! Watch him!
Old 01-12-2011, 03:59 PM   #29
Titus Wadicus
svtlx's Avatar
Re: Hard Launch Kit
cheese and rice!!!! how many trannies did he break to learn to shft that way
Old 01-12-2011, 04:00 PM   #30
Titus Wadicus
svtlx's Avatar
Re: Hard Launch Kit
it's guys like that the reason i run a racing aod
Old 01-12-2011, 04:03 PM   #31
drusmith's Avatar
Re: Hard Launch Kit
i love it!! I WANNA GO FAST!!!!!!!!!!!!!!!!!!!!!!
Old 01-12-2011, 04:04 PM   #32
He shifted early on the last pass. Gotta get all of 4th gear. 3rd is a long gear. It's all about seat and track time. Don't get discouraged your first time to the track. It will take a few trips. You gotta make passes and change launches and shift points. Racing a clock sucks.
Old 01-12-2011, 04:09 PM   #33
Titus Wadicus
svtlx's Avatar
Re: Hard Launch Kit
i coulda bought a t56 for wut i got in my aod..but i dont ***** bout it when im in 5oclock traffic..lol. i know better next time.
Old 01-13-2011, 10:28 AM   #34
drusmith's Avatar
Re: Hard Launch Kit
You are so right! I have dragged my SSEI about a dozen times and I kept getting better and better times! Best time was 13.6 which wasn't to bad for a 4000lbs car V6. LOL
I am going to practice a ton this summer! probably gonna go thru some tires!
rpm launch help 04machazblue 1996-2004 Mustang GT 23 11-12-2010 07:01 PM
Good RPM to launch at 67mustang97 1996-2004 Mustang GT 3 03-11-2010 06:15 PM
Now This is a Launch! bluemustang Pictures and Videos 2 09-08-2006 01:43 PM
Shuttle Launch a Success Brent The Bar 12 07-06-2006 01:47 AM
nice launch Warfire80 The Bar 6 05-21-2004 10:46 AM
11:51 PM
