Part Wanted! - Mustang Evolution
Old 01-11-2011, 09:54 PM   #1
Part Wanted!
Looking for a passenger window motor for a 96 gt vert.
DanielRz is offline   Reply With Quote
Old 01-11-2011, 10:04 PM   #2
MC770's Avatar
http://item.mobileweb.ebay.com/viewi...id=82878058809
If you are using a mobile device that link should work. If not go on eBay and type 96 mustang convertible passenger and it'll show up
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 01-11-2011, 10:05 PM   #3
Thanks, that was fast. How hard is it to install myself?
Old 01-11-2011, 10:07 PM   #4
MC770's Avatar
I can't imagine that it would be that hard, haven't done one myself though...
Old 01-11-2011, 10:42 PM   #5
Titus Wadicus
svtlx's Avatar
Re: Part Wanted!
make sure u got lotsa super glue...jk
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-12-2011, 01:13 AM   #6
Lol. Don't forget the duct tape!
93CobraGuy is offline   Reply With Quote
Old 01-12-2011, 03:27 AM   #7
Re: Part Wanted!
They can be a pain but can be done in about a hour. Just got to take your time and not get pissed when it seems like you cant get to the bolts.
Straublittleman is offline   Reply With Quote
Old 01-12-2011, 07:18 AM   #8
Re: Part Wanted!
a local pull a part junkyard is a great place to pick up that sort of stuff
Old 01-12-2011, 09:51 AM   #9
Titus Wadicus
svtlx's Avatar
Re: Part Wanted!
o snap...we forgot bail'n wire......good luck with the window. like straub said, a lil patience and u will be fine
Old 01-12-2011, 12:23 PM   #10
Lol.
Patience is definitely the key for pretty much any window motor!
Old 01-12-2011, 12:29 PM   #11
Titus Wadicus
svtlx's Avatar
Re: Part Wanted!
i put a 99 window motor in my 92. took some pateience cause they truely are 2 differnent motors. i made it work cause i was way too lazy to go back to the junkyard the day
Old 01-12-2011, 12:30 PM   #12
Titus Wadicus
svtlx's Avatar
Re: Part Wanted!
anyway, i think he's doin a window..which suks just as much.
Anyone looking for a certain part...? Black_Sunshine Pre-2005 V6 Mustang 0 07-11-2010 04:03 AM
ID THIS PART PLEASE ASHGATE6619 Pre-2005 V6 Mustang 11 11-17-2009 11:48 AM
Need some help with a part gregs_brat Pre-2005 V6 Mustang 10 07-10-2009 06:58 PM
Part numbers? MoOn-BaBy Pre-2005 V6 Mustang 1 10-26-2006 09:36 AM
02:14 PM
