Optima Battery!!! - Mustang Evolution
Old 01-13-2011, 11:04 AM   #1
drusmith's Avatar
Send a message via Yahoo to drusmith
Optima Battery!!!
Anyone have any experience, rants, or raves about these batteries? I am looking for extended audio time with car turned off, looks and dependability. REd top, yellow top?
drusmith is offline   Reply With Quote
Old 01-13-2011, 11:07 AM   #2
MC770's Avatar
Re: Optima Battery!!!
If you want a good battery for your audio go with Duralast from auto zone.
Put one of these in every car at my house and my dad's car has gone for a good 1hr to 2hrs listening to radio with the car off.
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 01-13-2011, 12:26 PM   #3
I have a red top...have had it for about a year now. I like it. I don't need extended audio with the radio off type stuff tho. I got it because my stocker was dying after 6 years and it had a red top to match my engine bay. I'll be getting a yellow top for the fox for the same reason.
However, I have had my radio on for 3-4 hours without issue while working in the garage...
Old 01-13-2011, 12:49 PM   #4
drusmith's Avatar
Yeah, thats pretty much why i want one! Just looks better in the engine bay! So should I go with yellow or red with my Sonic Blue termi?
Old 01-13-2011, 02:29 PM   #5
I've got one in my truck. Mustang next. They are lighter and not acid filled so they don't leak acid everywhere. Had mine for a couple years now and no issues at all.
Alscobra is offline   Reply With Quote
Old 01-13-2011, 02:46 PM   #6
drusmith's Avatar
Nice!!! I will buy one for sure!
Old 01-13-2011, 02:48 PM   #7
drusmith's Avatar
Should I get red or yellow?
Old 01-13-2011, 02:58 PM   #8
Never did that much research on it. Went with the red. The guy at the place where I bought it recommended it for my application.
Old 01-13-2011, 06:14 PM   #9
06mustangmike's Avatar
thanks guys u helped me out with an issue i"ve been having with my jeep, when i"m playing stereo with truck off.:}
06mustangmike is offline   Reply With Quote
Old 01-13-2011, 06:29 PM   #10
not sure its storage will be more, probably will, but that is what matters when it comes to how long it will last without charging~ they have a great reputation though.
If you have the OEM one it might be wise to consider changing, mine cranked fine, drive fine, then BAM dead wouldnt even jump....
also keep a close eye on your heat exchanger pump, heck might as well order a new one and install it and a heat exchanger if you are bored as they are known to go bad and there is NO warning light NO nothing... you find out the hard way (temps)
Old 01-13-2011, 10:39 PM   #11
I didn't have good luck with the three I had "red top" all three died around 4-5 months but thats when they first started coming out for sale, They may have improved on their workmanship but I'd go with the yellow top with the sonic blue car.
Straublittleman is offline   Reply With Quote
Old 01-14-2011, 09:20 AM   #12
drusmith's Avatar
I actually plan on installing the entire "Cool Pack"
http://www.rpmoutlet.com/images/rpm460411c.jpg
Old 01-14-2011, 09:30 AM   #13
nice, If I ever have my trans out I will install a cooling kit as well back there to help
Old 01-14-2011, 09:33 AM   #14
drusmith's Avatar
Good idea!!! What does that involve?
Old 01-14-2011, 10:18 AM   #15
I highly recommend against using rpm outhouse....do a search here and pretty much any other mustang forum and you will see why.
Also, the only thing that cool pack is, is a heat exchanger. The fluids can be had at any auto parts store...and the radiator resevoir if it is a canton has been known to split.
Check LethalPerformance.com for their cooling packs...but I really suggest against rpm outhouse.
Old 01-14-2011, 10:48 AM   #16
drusmith's Avatar
Thanks for the warning. I have not bought anything from them as of yet. They have good product list and good info. I already have a MI suppler (MRT) looking into the parts already. I will stay away from RPM!
Old 01-14-2011, 06:58 PM   #17
Totally right about that intercooler pump. Almost cooked my engine cause of that thing. Keep one close by.
Old 01-14-2011, 08:50 PM   #18
Honestly, if you plan on running it for extended periods of time without the car running I would recommend a blue top. These are marine grade batteries that are meant to be drained and charged repeatedly.
I personally have a red top and it doesn't take to storage very well. It replaced the stocker last year as it finally gave out. The red and yellow top are not meant to be run low often and if completely drained may never reach a full charge again.
Old 01-14-2011, 09:14 PM   #19
Whicked93Cobra's Avatar
Send a message via Yahoo to Whicked93Cobra Send a message via Skype™ to Whicked93Cobra
I have the red top in the trunk and have had no complaints so far.
As I lay rubber down the street,
I pray for traction I can keep,
But if I spin, and begin to slide,
Please dear God, protect my ride.
Whicked93Cobra is offline   Reply With Quote
Old 01-14-2011, 10:34 PM   #20
I've got a yellow top with a 4k watt PA Gothic class d amp and an alpine type x 12", hasn't let me down in 3 years.
19Delta is offline   Reply With Quote
Old 01-14-2011, 10:54 PM   #21
alexak187's Avatar
Region: Arkansas
I used to own a red top optima battery that i had on my 96 civic and had 2 15 jl audios with a 1000 watts amp and would always have it bumping loud for hours at a time when i was chillen with the boys and drinking and never once had to get a jump so in my opinion i would go for the red top its a good battery.
alexak187 is offline   Reply With Quote
Old 01-18-2011, 02:11 PM   #22
91GTstroked's Avatar
I'm trying to sell my red top, as I bought the car with it in there and I don't want to buy the bracket to hold it down. Going back to motorcraft. Heck my optima isn't even a year old, but its worked fine.
2003 REDFIRE SVT COBRA
455rwhp/480tq
91GTstroked is offline   Reply With Quote
Old 01-18-2011, 04:49 PM   #23
Invest in a tie down strap
Old 01-18-2011, 05:08 PM   #24
Or buy a $3 part from autozone....working great on my car, and Lowflyn's..
Lynx/Universal base mount battery hold down kit (LBHUS) | | AutoZone.com
Old 01-19-2011, 01:48 AM   #25
Ive had several Optimas. The red top is for just regular use, the yellow top is a deep cycle battery, which is good for sound systems and running them without the car on. The blue one is a marine battery and also a deep cycle. I love the yellow top myself, have had one in every car I had until just recently, and I will be getting another one. I once left my lights on in my "85 for about 3 or 4 hours and it started right up! So my opinion if you want to run any kind of stereo or system with the car off, get the yellow top!
93CobraGuy is offline   Reply With Quote
optima battery install 96mustanggt 1996-2004 Mustang GT 6 02-19-2009 01:22 PM
Yellow Top Optima Battery Smokedya95stang Mustang Parts for Sale and Wanted 6 02-14-2005 06:23 PM
25 Dollar Optima Batteries! Smokedya95stang The Bar 17 08-25-2004 05:33 PM
Optima Battery McGrail482 Pre-2005 V6 Mustang 6 04-25-2004 03:08 PM
02:40 AM
