Finding some one to work on my stang? - Mustang Evolution
Old 01-18-2011, 08:50 AM   #1
Loraco's Avatar
Send a message via Yahoo to Loraco
I need to find some one in AZ that won't f-up my car and won't rip me off? The check engine lights on now it was making a rattling noise when it was in idil but it didn't do it yesterday but now when I reach a certain RPM's my whole car shakes?
APRILS MOTM to drive is the reason the destination is just the excuse.
Loraco is offline   Reply With Quote
Old 01-18-2011, 08:55 AM   #2
Re: Finding some one to work on my stang?
If you take it to an autozone, oreillys, advanced auto, etc....you could get the check engine code read for free. Then come back here and post it up and we will be able to give you a relative idea what the problem is that's causing the check engine light.
The other issue, I'm not sure about and may or may not be related to the code you are throwing.
Either way, if you can get us the code, we can start trouble shooting it for you...then when you take it in for fixing you'll have an idea about what the problem is to curb some of the threat of being ripped off.
Old 01-18-2011, 08:55 AM   #3
Take it to a autozone or some place like that and have them read the codes "its free" then you can buy the part or atleast know whats wrong with it and take it to a mechanic when you find one.
Straublittleman is offline   Reply With Quote
Old 01-18-2011, 08:56 AM   #4
haha! you beat me LOL
Old 01-18-2011, 08:58 AM   #5
It happens....Imma ninja...
Old 01-18-2011, 08:58 AM   #6
Loraco's Avatar
Ok thanks going to find an auto zone close to me thanks guys!! Your awesome! Well post results as soon as I get them!!
Old 01-18-2011, 09:14 AM   #7
some autozones wont read code anymore and some will only let you do it yourself. Either way I am sure you can find someone to read them. Once you get the codes, write them down and post them up and lets see what we can figure out.
Old 01-18-2011, 09:23 AM   #8
Loraco's Avatar
Yes I have an auto zone not even 5 min from my house and the do read codes and will print them out for me!
Old 01-18-2011, 09:27 AM   #9
Camo1967Mustang's Avatar
That's y I love my sct tuner from am
It will read dtcs and I always have it with me just in case
Adrian
2001 Mustang
--AM CAI, BBK Headers, Dual exhaust, Billet grille, hood and side scoops, Sequential tail lights,
AM Headlight covers, Fog lights, Chin spoiler, H&R Lowering Springs, KYB Shocks and Struts
January 2012 StangAlley ROTM
Camo1967Mustang is offline   Reply With Quote
Old 01-18-2011, 10:45 AM   #10
yea I love my tuner but its is not compatible to read codes from my 05 sebring....
Old 01-18-2011, 11:07 AM   #11
Really? That sucks...I haven't tried it on a non ford yet, but I was able to read codes from a 2000 ranger with no problems. I thought it was able to read any ODB II car....
I need to find a non-ford to test on I think....
Old 01-18-2011, 11:26 AM   #12
Titus Wadicus
svtlx's Avatar
yea i know...i got a "innova " scanner. it wont read my gf's trail blazer, but it will read my ram. it reads on lexus, but wont read my 95 caprice. i got all the obd1 plugs and the obd2. i really hate that scanner.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-18-2011, 11:29 AM   #13
I thought so as well... It wouldnt read but I sent a clear command that seemed to remove the code (wanted to see if it would come back)
Old 01-18-2011, 01:37 PM   #14
Loraco's Avatar
got the codes the guy was real helpful he to is a mustang lover he is on his 3rd a 2001 gt nice!! heres the codes P0156 and P0161 he said it was the oxygen sensor
Old 01-18-2011, 01:40 PM   #15
I would think you can replace them, install MIL eliminators (dont work that great from what ive seen), or use a tuner and cut em off so the CEL doesnt come on.
A tune would kill two birds with one stone haha performance and no CEL.
Old 01-18-2011, 01:43 PM   #16
Loraco's Avatar
yea i just need the passenger side not to bad 43 bucks and i found a guy to work on it friend of a friend
Old 01-18-2011, 01:45 PM   #17
Loraco's Avatar
ok well i hope that dude that going to work on it knows that!
Old 01-18-2011, 01:46 PM   #18
you can get to it pretty easy, hard part is if its rusted in, should only take a few minutes to do if all goes well.
Old 01-18-2011, 01:47 PM   #19
Loraco's Avatar
thank you for your help
Old 01-18-2011, 01:49 PM   #20
Loraco's Avatar
it shouldn't be rusted it stays garaged and only has not even 40,000 on it
Old 01-18-2011, 01:55 PM   #21
yea should come out easy enough, they are just known to rust quick, a little antiseeze on reinstall is a good idea as well they say.
Old 01-18-2011, 01:58 PM   #22
Loraco's Avatar
do you think it bad for me to drive it tell it get fixed cause it probably wont be tell this weekend?
Old 01-18-2011, 02:00 PM   #23
it wont hurt anything of the 02 sensor is bad, gas mileage may suffer some
have a read How To Replace the Oxgyen Sensors on a Mustang
the MIL eliminators plug between the sensor and the harness
Old 01-19-2011, 09:08 AM   #24
Loraco's Avatar
This is very helpful! Thank you so much for your help it is greatly appreciated!!
Old 01-19-2011, 10:36 AM   #25
ibleedblue65's Avatar
What is p0156 & 161? I don't feel like looking it up. Just want to make sure you diagnose correctly. Never believe the guy at auto zone. They are just trying to sell you a part and will always tell you a code means you need this part. There are lots of 02 related codes. Rich, lean, switching, heater. All need to be diagnosed properly. I don't see sensors go bad as often a people think. Always amazed how often people change these.
ibleedblue65 is offline   Reply With Quote
Track Finding. Stumper General Mustang Discussion 0 03-28-2010 12:07 PM
help finding a site wkndpaintballer General Mustang Discussion 3 03-31-2009 06:39 PM
Need help finding a song... WhiteStang99 The Bar 10 07-04-2005 11:54 AM
Need help finding articles SpectorV The Bar 5 01-12-2005 06:20 PM
Need help finding a pic of the US SpectorV The Bar 7 01-06-2005 12:10 AM
09:30 AM
