Just got my dyno results(supercharged) - Mustang Evolution
Old 01-23-2011, 01:09 AM   #1
So after racing at qualcomm last night, me and my friend go to the a shop and dyno our cars. Mine is a 2000 vortech V1 supercharged gt at 7PSI and his is a 93 5.0
His first dyno came out to 175 hp and 230 tq. After 6 pulls Timing was added and final numbers were 214hp and 266tq.
My car goes up, and a problem came up. The car was running way too lean. I was very surprised with the numbers even though he did not step on all the way because it was too risky running that lean. My final numbers were 364hp and 372tq. He said to get the diablosport from the previous owner which he still has, and go back so the af ratio can be set. With that done I was told that it would be pushing over 430hp with the correct af
ID:	22952   Click image for larger version
Dnraiders is offline   Reply With Quote
Old 01-23-2011, 10:18 AM   #2
Re: Just got my dyno results(supercharged)
yea you had best not get on it running lean unless you like holes in your engine block lol those motors dont enjoy that kind of stuff.
Get it up to 9psi with a good CUSTOM tune (custom not just from vortech etc as those are nearly worthless) and you should be up to 400-430rwhp.
I would aim for 400 or so as those motors generally only hold about 450 max.
Old 01-23-2011, 10:50 AM   #3
Yea I was thinking since I have to tune it might as well bring the psi up. Forgot to mention that the engine is built and bored to 308 so I think a higher number is possible
Old 01-24-2011, 10:20 AM   #4
ah awesome you have much room to grow then, its all about getting the tune right get it safe but you have tons of room if the motor is built.
3.8 V6 dyno Tune Results robb15033 Pre-2005 V6 Mustang 12 11-27-2010 08:01 PM
dyno results are in (2.93 pulley) SpectorV 1996-2004 Mustang GT 10 01-19-2010 09:55 AM
Dyno results gmantheman 2005-2010 Mustang GT 11 10-07-2008 12:23 PM
SCT Tune / Dyno #2 Results 2005RedGT 1996-2004 Mustang GT 9 02-21-2005 09:36 AM
Air Silencer Dyno results ? drichard Pre-2005 V6 Mustang 4 10-15-2003 05:10 PM
11:23 AM
