Re doing heads - Mustang Evolution
Old 01-25-2011, 01:52 PM   #1
Re doing heads
Ok so I took my 01 cobra to a shop hear in oklahoma and I am having the heads redone do to a blown head gasket at first said around 2500 At most witch I thought was not to bad and then around 600 to re do the rear end and 4.10s so that's 3100 now they are saying 4000 makes no since does any one have a idea on price it should b they said the heads where really bad and had to b completely redone also what all has to b done does this sound normal and also it should take about a weak but it's been 4 going on 5 any one got any advice how I should handle this
Sick01cobra is offline   Reply With Quote
Old 01-25-2011, 01:55 PM   #2
Chick Nasty's Avatar
Send a message via AIM to Chick Nasty
Re: Re doing heads
havent thought about heads for mine...but i know install on gears can run up to 500 for install + gears themselves...good luck!
Chick Nasty is offline   Reply With Quote
Old 01-25-2011, 02:32 PM   #3
Titus Wadicus
svtlx's Avatar
Re: Re doing heads
u will be at 4300 by the time u pay taxes and wutever else. u may wanna get a second opinion, and pin them down with a written estimate and work to be completed..preferably itemized. so the price doesnt keep climb'n. not to mention..when the price keeps change'n, that tells me they never workd on cobra heads before..or cobras period for that matter. if they had done the work before they woulda knew wut to quote u off the back.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-25-2011, 09:52 PM   #4
TNTODC38107's Avatar
Re: Re doing heads
wow!! where do you guys stay? we had a 01 cobra in our shop and to redo the heads at our other shop was 250 per head and the labor charge was 800 bucks. that was for us to take off the heads, replace all gaskets and oil change, and put them back on. 4300 is alot.
TWO CHOICES I HAD. JUNK MY CAR OR LOSE MY WIFE......I WONDER HOW SHE'S DOING??
TNTODC38107 is offline   Reply With Quote
Old 01-25-2011, 11:47 PM   #5
I live in Oklahoma and yes that's what I said way to much I'm thinking about just giving them 3000 like they said in the first place I mean what can they really do about it do they really think I only have 1 set if keys lol plus going on 5 weeks to do a job that should take a weak tops
Old 01-26-2011, 12:01 AM   #6
Re: Re doing heads
Sounds like for that price you could have gotten some NEW heads and just reinstalled them yourself, and had a few bucks in your pocket to spare. That's a hellava lot of money for a job like that!
93CobraGuy is offline   Reply With Quote
Old 01-26-2011, 08:25 AM   #7
Re: Re doing heads
MMR will take your heads and give them a complete port job for $900...not sure what else you need done with your heads, but if porting is that cheap, your price is way up there. Hell, you could buy a pair of complete 03/04 cobra heads for 1/3 of that cost.
3.8 Heads kirbo7106 Pre-2005 V6 Mustang 5 01-28-2011 10:12 PM
PI heads jk7208 1996-2004 Mustang GT 3 07-07-2009 07:04 PM
heads johnnyc 1996-2004 Mustang GT 1 06-08-2009 06:29 PM
need help with heads johnnyc 1996-2004 Mustang GT 2 06-08-2009 01:15 AM
FS: BV Heads, 173's,Cam, and Stock Heads petrey10 Mustang Parts for Sale and Wanted 4 06-26-2006 11:15 PM
10:13 AM
