How to pull more power from your pony - Mustang Evolution
Old 01-27-2011, 09:30 AM   #1
CrimsonGT's Avatar
Ok guys this is a common desire for everyone
Let's say for instance you have a mustang gt that's starting to get up there in mileage odds are you are losing HP somewhere.
Its a sad fact but the older the car usually the more power it's lost
If your like me you have probably put in an exhaust or intake or new sparkplugs basically something affordable to make up for this loss
Now here is the question
Let's give it a budget of 500$ not much I know but the economy blows lol
How would you get the best out of your pony?
CrimsonGT is offline   Reply With Quote
Old 01-27-2011, 10:03 AM   #2
Re: How to pull more power from your pony
I would start off with a little tune up, nothing crazy.
spark plugs are cheap, replace them (use ford brand gaped right no need to spend tons of money on Iridium etc just get the OEM ones that came in the car)
run sea foam in the car to clean out carbon deposits
change fuel filter (easy and cheap)
clean maf sensor with electronic no residue on contact cleaner
change rear diff fluid if around 100k or so and put in fully synth fluid of correct weight and with correct additives
if manual change the trans fluid its cheap and easy, use OEM spec fluid if auto it will be a little harder so may want to wait on this.
Change air filter, or install a CAI
All the above will probably cost 100-250 bucks if you do it yourself and what type of CAI you go with
For the rest (250-300~) maybe mufflers and an under drive pulley~ a tune would be nice but will cost more with the handheld.
Old 01-27-2011, 02:02 PM   #3
Rosco's Avatar
Great information Spector. I was wondering the same thing for my pony. I noticed about a week ago for the first that my clutch caught I had let fully off of it and the clutch slowly let go, letting the rpms shoot up. Can you suggest any thing for a manual v6 tune up that wasn't already mentioned.
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 01-27-2011, 02:41 PM   #4
if your rpms are rising and you have your clutch out (in gear fully) it could be the clutch is going lol you may need to look into replacing it its not to expensive but you should replace all bearings and inspect input shaft tolerance for spec and all that good stuff.
Old 01-27-2011, 03:51 PM   #5
A cai is a waste of money on a new edge
Old 01-30-2011, 12:01 AM   #6
doubletap4311's Avatar
4.10 gears will make you feel like you gained 100hp
doubletap4311 is offline   Reply With Quote
Old 01-30-2011, 02:52 PM   #7
Mustang339's Avatar
Region: Utah
What is sea foam?
1996 Mustang GT Mine
2003 Mustang GT Vert Wife
Mustang339 is offline   Reply With Quote
Old 01-30-2011, 02:57 PM   #8
Rosco's Avatar
I was hoping this wouldn't be the answer. Ive read that you've had a few 3.8s. Do you have certain clutch to recommend.
Old 01-30-2011, 04:16 PM   #9
cherrybomb's Avatar
I've heard bad things about the underdrive pulleys, doesn't it throw everything else off?
cherrybomb is offline   Reply With Quote
My Dyno Pull!!! zztop1234 General Mustang Discussion 46 08-28-2010 03:41 PM
Redneck Tractor Pull at7311 The Bar 9 06-04-2008 10:17 PM
Pull up your pants...NOW!!!! PureVenom The Bar 8 06-14-2007 04:07 PM
Whats this tard trying to pull?? SpectorV The Bar 1 11-01-2005 06:38 PM
99 FR350 DYNO pull 99FR350 Pre-2005 V6 Mustang 4 10-11-2003 03:09 PM
07:47 PM
