Rear end gear swap - Mustang Evolution
Old 01-30-2011, 10:07 AM   #1
Rear end gear swap
With gears from an 06 fit in a 98? Both are GT
Davenlindas98gt is offline   Reply With Quote
Old 01-30-2011, 10:08 AM   #2
Will oops lol
Old 01-31-2011, 02:51 AM   #3
Re: Rear end gear swap
If you are meaning the whole rear end then yes it will but its like 3/4 of an inch wider. If you mean just the gears then yes but its better to buy new ones because all rearends are made a little different and shimmed different which means when those gears are installed they wear their own pattern and when you install them in a different rear end they usually make a whining sound unless installed perfectly.
Straublittleman is offline   Reply With Quote
Old 01-31-2011, 07:36 AM   #4
the gears should work unless they messed around with something in the later years, I wouldnt put used gears in my car though~
Old 01-31-2011, 02:27 PM   #5
That's the difference of some one that knows how to set up a rear end or doesnt tho right? Used gears or not it's all in the set up if I'm not mistaken.
Old 01-31-2011, 02:41 PM   #6
What he said!
I wouldn't put used ones in mine either.
93CobraGuy is offline   Reply With Quote
Highway RPMs after Rear Gear Swap charrier90 Pre-2005 V6 Mustang 2 06-07-2010 05:33 PM
Rear End Gear FAQ OsirisGuy General Mustang Discussion 18 11-10-2009 12:22 AM
rear end swap 98mustang2007 Pre-2005 V6 Mustang 2 11-11-2007 06:21 PM
1996 Mustang GT rear end gear ratio Buzz 1996-2004 Mustang GT 2 04-23-2006 07:19 PM
Rear end gear!!!!!!!!!!!!!!!! coolstang Pre-2005 V6 Mustang 27 11-10-2004 12:56 AM
01:40 AM
