Car idle bad - Mustang Evolution
Old 01-30-2011, 05:43 PM   #1
Jamesgt08's Avatar
Car idle bad
My 2000 gt idles bad idk what it could be. When i put it in drive an go it struggles to go i have to press the gas hard to go. What could it be?
Jamesgt08 is offline   Reply With Quote
Old 01-30-2011, 06:06 PM   #2
Re: Car idle bad
Is the check engine light on?
93CobraGuy is offline   Reply With Quote
Old 01-30-2011, 06:07 PM   #3
Jamesgt08's Avatar
Yea sometimes it comes on. But i tuned my car.
Old 01-30-2011, 06:11 PM   #4
Re: Car idle bad
Does your tuner read trouble codes as well?
Old 01-30-2011, 06:16 PM   #5
Jamesgt08's Avatar
No it doesnt. But ive had numerous ppl look at it with computers. Most codes say vacuum leak fuel to rich or to lean MAF is bad.
Old 01-30-2011, 06:25 PM   #6
Re: Car idle bad
Then that's why your car is running like sh**. New Mass Airflow Sensor time.
Old 01-31-2011, 01:46 AM   #7
Re: Car idle bad
I'd try cleaning the mass air first, nearly all auto parts places can get a can of spray that will clean it. Also invest in a set of security torx bits so you can take the MAF apart.
Straublittleman is offline   Reply With Quote
Old 01-31-2011, 06:01 AM   #8
Jamesgt08's Avatar
Ive already cleaned the mass air i took all apart and cleaned it with that spray.
Old 01-31-2011, 12:43 PM   #9
Re: Car idle bad
Those things are pretty sensitive, was it acting that way before you took it apart?
Old 01-31-2011, 12:58 PM   #10
Jamesgt08's Avatar
Yea it was already doing that before i took it apart. When im at a dead stop and hit the gas it hesitates then i gas it more then it goes.
Old 01-31-2011, 01:29 PM   #11
Re: Car idle bad
Ouch, sounds like its time for a new one. You might be able to get one at a salvage yard way cheaper than new, but I know they aren't cheap anyway, so check their price and then check on a new one. The price difference should negate whether or not to go new or used. IMO I would go for a new one, but that's just me.
Old 01-31-2011, 01:30 PM   #12
Jamesgt08's Avatar
Yea ima get a new one. But is that my problem?
Old 01-31-2011, 01:42 PM   #13
Re: Car idle bad
I would say probably so. Those things control a lot of readings for the computer. Controls the amount of fuel the computer tells the injectors to squirt, things like that. So if it's reading lean, and rich in the trouble codes, and that the MAF is bad, I would say with certainty that this is your problem.
Old 01-31-2011, 01:43 PM   #14
Jamesgt08's Avatar
Ok thanks for the help ima go buy a new one tomorrow then. Hopefully it cures my stangs problem.
Old 01-31-2011, 07:37 PM   #15
Check your PVC valve too. I had a friend who almost swapped his piston rings cuz he thought they were bad, it turned out that the pcv valve was just bad.
Chancewendt is offline   Reply With Quote
Old 01-31-2011, 07:43 PM   #16
Jamesgt08's Avatar
Where is the pcv valve located?
Old 01-31-2011, 07:49 PM   #17
Jamesgt08's Avatar
I already changed out my pcv valve.
need someone to listen to their car idle shelbygt07 2005-2010 Mustang GT 5 05-01-2008 07:06 AM
Car is messed up bad now..... Kiljosh The Bar 12 11-27-2006 10:38 PM
Bad Idle JustlikeaFox 1979-1995 Mustang GT 1 11-22-2006 03:52 PM
My car seems to idle rellay rough, and miss badly johnpittbull 1979-1995 Mustang GT 21 07-04-2006 09:06 AM
Code reading? and Car that idle Lobes and stalls stick0014 Pre-2005 V6 Mustang 4 09-03-2004 08:33 PM
03:32 PM
