Which spark plugs do you run? - Mustang Evolution
Old 02-01-2011, 08:27 PM   #1
systemdz's Avatar
I'm changing the plugs in my car. It had Bosch fusion's in it when I bought it and I'm changing them with NGK TR55ix iridium plugs. What plugs do you run?
Friends don't let friends drive Chevys, hang on, friends don't have friends that drive Chevys!!!!
systemdz is offline   Reply With Quote
Old 02-01-2011, 08:36 PM   #2
Re: Which spark plugs do you run?
OEM plugs will work just as good as any, I am currently runing TR6-IX due to my OEM are Iridium and I needed a diff heat range.
Old 02-01-2011, 09:07 PM   #3
Bosch platinum/iridium 4 ground strap electrode plugs. N I am giving them away because I need nitrous plugs
Old 02-01-2011, 09:10 PM   #4
NGK V-Power baby!!!
93CobraGuy is offline   Reply With Quote
Old 02-01-2011, 09:49 PM   #5
For a close to stock GT run autolites and be done with it, you're just throwing away money otherwise.
In the cobra I run NGK TR6 coppers. Change them every 6 months like clockwork.
Old 02-02-2011, 05:46 AM   #6
doubletap4311's Avatar
NGK TR55
doubletap4311 is offline   Reply With Quote
Old 02-02-2011, 06:26 AM   #7
stampde's Avatar
AutoLite XP's in the Mach 1 , AutoLite Platinum in my v6
2011 GT Auto
Old 02-02-2011, 05:46 PM   #8
stangstar92's Avatar
if you ever run nitrous, platinums are no good
2002 Gt Mustang - Built 2 Valve
"Real cars don't power the front wheels...they lift them"
stangstar92 is offline   Reply With Quote
Old 02-02-2011, 05:58 PM   #9
Yup....were bad
Old 02-02-2011, 06:13 PM   #10
systemdz's Avatar
I put my NGK's today. Granted the Bosch plugs that were in it was old, but my car is a lot smoother idling now than it was before. 2 thumbs up for NGK
Old 02-02-2011, 09:56 PM   #11
CrimsonGT's Avatar
E3.54 for me I read all their research and even watched a speed channel special with before and after dynos on e3 plugs and decided they were best choice for me
But the debate is still continuing on which plugs are best
But I'm happy so far had em for a while
CrimsonGT is offline   Reply With Quote
Old 02-02-2011, 10:37 PM   #12
I'm simply wondering when people will realize manufacturers recommend a certain product because that is the exact product they designed for that specific application.
Everything else that is sold out there is a money-making tool for someone else.
There is no need for a double-platinum 5 tipped plug, but I'm sure it will be out there soon.
I'll state my case again.
I run a TR6 in the cobra. It's a single fire, copper based, normal plug. It gives me over 500 hp to the wheels in a supercharged application.
If it will work in that car there is no reason a normal copper plug won't work in your application.
With that said, keep wasting your money on plugs, gas, and additives your car doesn't need. I'll keep the money in my pocket.
Old 02-02-2011, 11:23 PM   #13
bbunt302's Avatar
Autolites FTW.
Scary stuff.
Old 02-03-2011, 09:50 AM   #14
SaleenFiend's Avatar
If you don't have a specific need for different plugs then you need to run OEM or Autozone Autolite OEM replacements.
Old 02-03-2011, 01:25 PM   #15
have tried other plugs and i always go back to motorcraft plats
white98gt is offline   Reply With Quote
Old 02-03-2011, 01:59 PM   #16
04machazblue's Avatar
Motorcraft only Bosch fail out they are junk. Motorcraft oem plugs are the best. That is what ur car leaves the factory with
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
what spark plugs do i need fastfanatic 1996-2004 Mustang GT 6 09-14-2009 08:23 PM
What spark plugs should I go with? Frogleg 1996-2004 Mustang GT 30 06-21-2009 03:44 AM
E3 Spark Plugs ? occhopperman27 New Member Introductions & Greetings 6 06-19-2009 04:03 PM
Spark Plugs drkchocolate07 Pre-2005 V6 Mustang 9 05-10-2009 01:29 PM
Which spark plugs should I use??? koch_A_tyler 1996-2004 Mustang GT 5 03-18-2008 06:36 AM
11:06 PM
