timing chain ?'s - Mustang Evolution
Old 02-03-2011, 01:21 PM   #1
timing chain ?'s
hey guys, i'm gonna do the pi swap soon. should i replace the chains? have read the ford timing chains are really long lasting. some say if no noises and such don't change them, but replace the guides & tensioners. engine has 151,000 on it really no problems but a little smoke sometimes from the valve seals. don't really have any questions about the swap itself, have been doing ALOT of research. anyway, whatever you can school me on is much appreciated. thanks...
white98gt is offline   Reply With Quote
Old 02-03-2011, 02:05 PM   #2
Re: timing chain ?'s
If it were mine, I would replace the chains. They aren't that expensive, and if they do fail in the future you're going to have to tear the engine back down to replace them. That's just me though.
93CobraGuy is offline   Reply With Quote
Old 02-03-2011, 02:30 PM   #3
Titus Wadicus
svtlx's Avatar
replacing the guides and tensioners is what i was told too.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-03-2011, 02:34 PM   #4
thanks for the input guys.
Old 02-04-2011, 07:15 AM   #5
little cost now, save time and money down the road
Old 02-04-2011, 08:22 AM   #6
stampde's Avatar
4.6 ??? I'd do the chains while its apart . there's a million bolts on that timing cover so why do it again later ? replace them now while you've got it apart .
2011 GT Auto
Old 02-04-2011, 09:04 AM   #7
ibleedblue65's Avatar
Depends on price. I've never had to replace chains on a mod, now a sohc four liter that's a different story. I don't really think its necessary personally but to each his own. Also guides don't really need replacing and neither do tensioners unless the guides are worn our the seal on the back of the tensioner is done. Not a bad idea to go ahead and get the parts and if you don't need them you can always return them.
ibleedblue65 is offline   Reply With Quote
Timing Chain Needed! tjzola 1996-2004 Mustang GT 3 06-02-2010 01:30 AM
Brand New in Package Ford Racing Double Roller Timing Chain Set wvstang5.0ho Mustang Parts for Sale and Wanted 2 01-31-2009 06:13 AM
Car Restoration Chain of Events: Need help PureVenom General Mustang Discussion 6 10-14-2008 11:43 AM
High on the Mustang evolution chain 69boss429 New Member Introductions & Greetings 14 09-08-2006 09:41 AM
Chain E-mail, but this one is worth reading. WhiteStang99 The Bar 5 07-13-2004 12:19 PM
04:43 AM
