Need a supercharger - Mustang Evolution
Old 02-03-2011, 01:23 PM   #1
Need a supercharger
Ok, so I don't really need it but I want it! Does anyone know where I can get 2002 roush supercharger? I guess roush isn't making them anymore. Or should I go with a different brand?
2002roushstang is offline   Reply With Quote
Old 02-03-2011, 02:09 PM   #2
Try eBay, you can find some ppl that upgraded to wipple on line and they are trying to get rid of some...
Ducatisport is offline   Reply With Quote
Old 02-03-2011, 02:11 PM   #3
Just type roush supercharger into the search bar on eBay and you will find a bunch
Old 02-03-2011, 02:32 PM   #4
Titus Wadicus
svtlx's Avatar
Re: Need a supercharger
just make sure you are getting everything you need for the install. partial kits get sold alot on ebay...know wut u need.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-03-2011, 02:44 PM   #5
I see a lot of research headed my way
Old 02-03-2011, 03:13 PM   #6
Titus Wadicus
svtlx's Avatar
dont forget bout the fuel pump and injectors...lol. you definatley need to take your time and see wut u need before you buy anything from anyone. take a look at some other ppl' cars that are set-up already so u know what parts you need. compare engine bay to engine bay.
Old 02-03-2011, 03:58 PM   #7
Good advice!
supercharger... johnnyc 1996-2004 Mustang GT 15 08-16-2009 03:25 AM
used supercharger for v6? 05cobra Pre-2005 V6 Mustang 0 01-31-2007 11:00 PM
Supercharger ridenmystang 1996-2004 Mustang GT 36 07-25-2006 09:28 AM
Supercharger? 19ClearCobra96 The Bar 16 01-17-2005 10:29 PM
08:57 PM
