BBK problem - Mustang Evolution
Old 07-18-2007, 08:42 PM   #1
BBK problem
I ordered bbk lts and an offraod h. When i went to put on the h pipe it didn't line up right(and no its not upside down). The cup on the passenger side of the h fits perfect with the ball of the header but the drive side is cocked but it fits in the ball but is angled like the h pipe isn't wide enough. I also tried puttin on the driver sied first but i hade to push the pipe on the passenger using my foot while a buddy hooked it up. all it did was move the driver side and still leaked. Any suggestions?
UTGT is offline   Reply With Quote
Old 07-18-2007, 08:57 PM   #2
hottcobra's Avatar
Re: BBK problem
I've had to put ratchet strip to both headers to pull them together before you can try that
Old 07-19-2007, 09:17 AM   #3
Re: BBK problem
they may require a different H pipe, might want to check with BBK to make sure.
Old 07-19-2007, 11:21 AM   #4
maximus's Avatar
Re: BBK problem
yea, the bbk lts are made to use a bbk only x/h pipe. otherwise you have to custom fab the pipe you bought.
I know this because I have both.
maximus is offline   Reply With Quote
Old 07-19-2007, 02:36 PM   #5
Re: BBK problem
the h pipe is bbk
Old 07-19-2007, 04:45 PM   #6
maximus's Avatar
Re: BBK problem
yea but was it made to specifically fit the bbk lts? bcuz im pretty sure you cant use a regular bbk h-pipe and hook it up to the lts.
Old 07-19-2007, 08:36 PM   #7
Re: BBK problem
Yes it is the short h for lts. If it wasn't it would be way to long and be bent up towards the manifolds!
Old 07-19-2007, 08:39 PM   #8
Send a message via MSN to 1996stang Send a message via Yahoo to 1996stang
Re: BBK problem
I know the 96-98 and the 99-04 flange is different i ran into this problem when i did the motor swap.Might check and see if that could be a problem.They might be a different width also
2004 mach 1 stock and staying that way.
1996stang is offline   Reply With Quote
Old 07-20-2007, 04:17 AM   #9
maximus's Avatar
Re: BBK problem
id just suggest getting in contact with either a cs person from BBK or a mechanic from a shop that does regular work on mustangs.
Old 07-20-2007, 11:05 AM   #10
95&modified's Avatar
Re: BBK problem
It's not a drop top is it? Read while looking for mine that alot of the parts I looked at said they wouldn't fit.
95&modified is offline   Reply With Quote
Old 07-24-2007, 05:12 PM   #11
Re: BBK problem
bbk is sending me a new h. i'll let you know how it goes!
Old 04-04-2014, 11:34 PM   #12
FullyAutomatic's Avatar
Region: Mexico
how did it go?
FullyAutomatic is offline   Reply With Quote
BBK shorty help outlawfrog 1996-2004 Mustang GT 23 11-27-2009 08:31 PM
bbk headers dshultz88 Pre-2005 V6 Mustang 5 12-10-2007 11:28 PM
02-03 gt BBK CAI F/S stanger99 Mustang Parts for Sale and Wanted 9 05-19-2007 01:10 AM
BBK CAI RedDragonV6 Pre-2005 V6 Mustang 2 02-16-2004 09:13 AM
12:08 PM
