Problem after typhoon intake manifold install. - Mustang Evolution
Old 02-07-2011, 09:05 AM   #1
RudyJ's Avatar
I just installed my typhoon inatake manifold, MSD blaster coils & a new Optima battery. Everything looks great but now it wont start. I ve checked over everything & it all good good. When put the key in my gauges sweep & everthing looks the way its suppose to but when I try to start her I just hear a clicking sound & its like I have no more power from the battery but its new & I have test light that came with it & it shows the battery is good. Anybody have any ideas on what can be the problem? Thanks in advance.
RudyJ is offline   Reply With Quote
Old 02-07-2011, 09:22 AM   #2
stampde's Avatar
Re: Problem after typhoon intake manifold install.
just sounds like a bad connection at the battery , clean your cables and re tighten them
2011 GT Auto
Old 02-07-2011, 09:27 AM   #3
when the needles flip like that its a sign the car lost its battery or the battery is not performing right, it happens when you disconnect and reconnect the battery for example.
Old 02-07-2011, 10:54 AM   #4
RudyJ's Avatar
Well, it was a bad connection. But now it idles realy bad. I have to stay on the throttle or it stalls.
Old 02-07-2011, 11:26 AM   #5
doubletap4311's Avatar
Either bad coil or vacuum leak
2002 Gt, 5 speed, BBK Cai, BBK 78 MM intake plenum combo, steeda UDP, steeda tri axe shifter, 4.10 Ford racing gears, Sct custom tune, raptor shift light.
doubletap4311 is offline   Reply With Quote
Old 02-07-2011, 01:39 PM   #6
stampde's Avatar
yup what doubletap said !!! i'd lean toward vacuum leak
2011 GT Auto
Old 02-09-2011, 04:41 PM   #7
iwannagofast's Avatar
Did you have a dyno before this intake? if yes, get another one done now. I've heard alot about typhoons causing hp and torque loss
iwannagofast is offline   Reply With Quote
Old 02-09-2011, 10:06 PM   #8
Ditto
Old 02-10-2011, 08:13 AM   #9
DarkShadows's Avatar
Installed intake, and had mine retuned and runs strong for me now!!
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 02-12-2011, 05:53 AM   #10
I have a K&N on mine and have no issues. I believe you forgot to hook up a vac line or two somewhere. Anyhow, I have heard the CAI's don't do what they are worth. Just an add on that looks good. Anyone feel free to correct me if I am wrong. Anywhere from 100 to 200 dollars is not worth a 5 to 10 HP gain to me.
Jdaddy42 is offline   Reply With Quote
Old 02-12-2011, 06:06 AM   #11
On a new edge you dont even get that. 05 and up need a tune or it's a waste of money
Old 02-12-2011, 06:46 AM   #12
Wolfsbain76's Avatar
That's so good to know, I would have installed it and not even have known! I absolutely love being a part of a group with knowledge!! Looks like a summertime project then. Thanks for the heads up!
2007 Mustang GT
Wolfsbain76 is offline   Reply With Quote
03:25 PM
