Door Glass to Regulator Brackets - Mustang Evolution
Old 02-08-2011, 10:34 AM   #1
MustangMafia97's Avatar
Send a message via AIM to MustangMafia97
Hey guys, on my 1997, the pass. side door glass. The brackets that connect the glass to the door regulator has unglued it self from the glass. The glass is getting worse and worse when rolling it up now. What would be recommended? I have previously taken two regulators out of mustangs, a 1994(manual) and 1997(electric) the 1994 was riveted in, the 1997 was just bolted in except the 2 rivets between the regulator to the glass, Not fun at all if have done this, I don't want to do that, but if it comes to that... From what i can tell about in 1996 or 1997 they started bolting the regulator in instead of rivets. If possible what glue could I use?
Nothing but Ford...Nothing but American Muscle
MustangMafia97 is offline   Reply With Quote
Old 02-08-2011, 10:40 AM   #2
I've used that 5 or 10 minute epoxy on those before. It comes in a double tube from any auto parts store. You squeeze equal amounts out and mix them together. Works great. Toughest glue I've found. Will hold on to anything.
Alscobra is offline   Reply With Quote
Old 02-08-2011, 11:23 AM   #3
Titus Wadicus
svtlx's Avatar
Re: Door Glass to Regulator Brackets
i used clear silicone, left the window rolled up all the way all nite...never came loose again.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-09-2011, 12:31 AM   #4
JB Weld will work too, I use it for just about anything I need to put back together, well, anything that's not on my Mustang!
93CobraGuy is offline   Reply With Quote
Old 02-09-2011, 07:30 AM   #5
lol, I'm going to try the glue first, a lot easier that replacing the entire assembly
Seat Brackets TheEzyLife Pre-2005 V6 Mustang 1 08-26-2009 12:29 PM
1969 Mustang Door Glass Question BruThru2002 Mustang Audio & Video 3 12-16-2007 06:47 PM
voltage regulator white 98 gt 1996-2004 Mustang GT 3 08-30-2006 03:00 PM
fuel presure regulator hose? blk2kconvstang Pre-2005 V6 Mustang 0 03-07-2004 01:00 PM
04:31 PM
