98 Mustang Gt Not running - Mustang Evolution
Old 02-08-2011, 07:20 PM   #1
I have a 98 Mustang Gt with 4.6 liter engine. I go to start it up and it shuts off. white smoke comes out of exhaust pipes. Smell like excessive gas, car will not run unless gas pedal is pushed. believe it to be a fuel system problem. Anybody here of this problem?
Mustanggt9t4 is offline   Reply With Quote
Old 02-08-2011, 08:21 PM   #2
Re: 98 Mustang Gt Not running
Hi,I have some similar problems with my 2005 gt . The battery went flat,when I was changeing the evolution open air kit,back to the original air cleaner box ! When I had the batteri charged again,the engine would not go normal ! It is on the edge to stop,if I dont pushing the throttle easely,and it smokes and smell gasoline ?????
Simon A Simons is offline   Reply With Quote
Old 02-08-2011, 08:41 PM   #3
I started having problems after changing the intake. it had a plastic water jacket now has a metal water jacket in it. the check engine light has been on for two months.
Old 02-08-2011, 08:52 PM   #4
Have you had the trouble codes read?
93CobraGuy is offline   Reply With Quote
Old 02-08-2011, 09:06 PM   #5
yes the guy told me it was something with fuel system but it was a generic code, He told me it could be one of 25 things, so he told me to try cleaning mass air flow sensor. that did not work.
Old 02-09-2011, 09:08 AM   #6
When were the plugs changed last and are the coils ok
Old 02-09-2011, 05:12 PM   #7
Hi ! no I have not get hands on one OBD scanner yet ! I know it is more than one error code on the dash,so u think it is the only reason,that it wont idle !!! Tnx for speedy answer I `ve just reg, me yesterday evening,så it take som time to understand how to reply and so,and I am Swedish
Old 02-09-2011, 05:33 PM   #8
Buy a tuner. It will diagnose and clear codes and they tune the engine for more power
Old 02-10-2011, 05:57 AM   #9
Plugs were changed when we changed intake and wires were changed last month. it seems to be getting spark. It just wont stay running unless you are on the gas pedal.
Running Moonshine In A Mustang Brent The Bar 7 12-04-2010 02:09 PM
87 Mustang has very high idle and running VERY rich. Any ideas? clannan1 1979-1995 Mustang GT 5 08-21-2010 12:25 PM
91 Mustang GT 306 Running Pretty Hot! 91StangGT5.0 1979-1995 Mustang GT 8 10-22-2009 09:01 PM
02:20 AM
