Charging issue - Mustang Evolution
Old 02-10-2011, 07:12 AM   #1
04_GT's Avatar
Charging issue
Ok so my battery has not been holding a charge, I have been having to charge it about every other day. This has been happening consistently since I put new pulleys in it about a month ago. I never heard anyone say that this would be an issue when I was looking at pulleys so I didnt even think about it. When I am sitting at an idle the battery gauge drops down quite a bit but as soon as a rev it or drive then it will go back up.
Borla Stinger Cat-Back, Cold Air Intake, 70mm Throttle Body, Underdrive Pulleys, Diablo Predator Tuner, H&R Lowering Springs, Tokico Shocks/Struts, Mach 1 Chin Spoiler, Smoked Taillights
04_GT is offline   Reply With Quote
Old 02-10-2011, 08:13 AM   #2
Joshy's Avatar
U put some water in it?
www.petom.biz
Joshy is offline   Reply With Quote
Old 02-10-2011, 10:32 AM   #3
Titus Wadicus
svtlx's Avatar
Re: Charging issue
make sure it is de-ionized water....not tap
sounds like your battery wasnt a happy camper to start with. charging problems and sometimes even cooling problems are commonly associated with under drive kits...some brands are more prone than others. i cant tell you which brands are the good ones.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-10-2011, 02:08 PM   #4
Re: Charging issue
Even with an underdrive pulley, it should still be charging while driving. If it were me, and since it's free and easy to do, take it on up to the local parts store and have them test the battery and the alternator. When testing the alternator though, manipulate the throttle to a higher idle, that way you know for sure it's not that. That will be a pretty clear indication on what's going on.
93CobraGuy is offline   Reply With Quote
Old 02-10-2011, 02:12 PM   #5
Titus Wadicus
svtlx's Avatar
Re: Charging issue
he said only at idle...not when he's drivin.
Old 02-10-2011, 02:17 PM   #6
Re: Charging issue
He also said the battery hasn't been holding a charge and that he had to charge it every other day, my guess is that his battery is junk.
Old 02-10-2011, 02:20 PM   #7
Titus Wadicus
svtlx's Avatar
Re: Charging issue
that's wut i said...lololol
Old 02-10-2011, 02:27 PM   #8
Re: Charging issue
Old 02-10-2011, 09:35 PM   #9
Joshy's Avatar
Use an F650 to tow it back home when the battery quits.
www.petom.biz
Old 02-10-2011, 09:43 PM   #10
Ha... A 150 will do er too... Good one lil mustanger
Old 02-10-2011, 09:55 PM   #11
bbunt302's Avatar
Re: Charging issue
You may have a couple problems here contributing to what you're seeing. First, it sounds like the battery is on its last legs.
Second, did you actually change the pullies on the alternator? If so, you may want to consider swapping the stock alternator pulley back on. There are also companies that sell overdrive alternator pullies to account for this very problem. It's a pretty common issue with underdrive pullies. Some people have issues, some don't. The crank pulley is really where the big benefit is coming from anyway though, so you're not losing much power by going back to the stock alternator pulley, or even upgrading to an overdrive pulley.
Scary stuff.
Old 02-10-2011, 09:59 PM   #12
Re: Charging issue
This is the exact thing that Ford did on the "93 Cobra.
Old 02-12-2011, 07:30 PM   #13
doubletap4311's Avatar
I put on steeda's. They are the only ones to use in my opinion. I have never had a charging or temperature issue. Either your battery is weak or you have issues with your alternator. What brand of pulleys did you put on?
2002 Gt, 5 speed, BBK Cai, BBK 78 MM intake plenum combo, steeda UDP, steeda tri axe shifter, 4.10 Ford racing gears, Sct custom tune, raptor shift light.
doubletap4311 is offline   Reply With Quote
05 v6 charging issues obxdude018 Pre-2005 V6 Mustang 3 11-22-2010 03:32 PM
A charging system question... silverstang 1996-2004 Mustang GT 1 03-09-2008 07:40 PM
charging system woes Thomas91169 Mustang Audio & Video 15 08-12-2006 12:34 AM
PLEASE Help!! charging issues...91 GT scorpionSStang 1979-1995 Mustang GT 11 02-10-2006 04:56 PM
battery charging problem I_luv_HP&trq Pre-2005 V6 Mustang 20 09-24-2005 02:58 AM
12:06 PM
