Help, rear axle bearing is bad - Mustang Evolution
Old 02-12-2011, 03:28 PM   #1
I have a 1996 gt and just installed some 18's, rear axle bearing is bad I think, how big of a job is it to change both bearings and seals,and how do I go about it?
Banshee is offline   Reply With Quote
Old 02-13-2011, 05:33 PM   #2
Re: Help, rear axle bearing is bad
It's not too bad. Pull the wheels, then brakes. Pull the diff cover, then pull the center pin out of the t-lock(held in by one 8mm bolt), then push the axles in and remove the c-clips, then remove the axles, pull the old seals and bearings, put the new ones in and reverse the procedure. You will need a slide hammer to remove the old bearings.
-Daniel
2000 Vert, 4.6 SOHC swap, old set-up intercooled s-trim @11lbs..New setup-5.0 stroker, stage 2 heads, kenne bell 2.2l with a 2.75"
daniel302 is offline   Reply With Quote
Replacing rear bearing Dmay65 Classic Mustangs 14 01-20-2011 07:29 PM
Supercharging and replacing rear axle and gears for my mustang 2008 bmx_20055 Pre-2005 V6 Mustang 25 02-07-2009 09:06 AM
Torque Arm for a 7.5 rear axle fastmustangs1 Pre-2005 V6 Mustang 6 02-17-2005 02:01 PM
Best T/O Bearing? 97Stallion Pre-2005 V6 Mustang 2 08-28-2004 04:29 PM
Rear Axle Bumpstop njstang97 Pre-2005 V6 Mustang 2 07-01-2004 10:17 AM
11:09 PM
