cobra dash cluster swap! - Mustang Evolution
Old 02-14-2011, 03:06 PM   #1
so for those of you who wanted to swap their dash clusters and who were worried about the PATS system and how to get past it here is a little write up on it. i looked into it and there was just alot of TALK on this, nobody has done it so i did!
what you will need...
1. pair of needle nose plires
2. tork screw drivers
3. small flat head screw drivery
i also went to youtube and found a step by ste process on my iphone on how to remove everything. heres the link
1. first you will need to remove the benzel infornt of the cluster.
1a.you do this by disconnecting the battery before anything.
2a.pull out your headlight nob all the way. then with a small flat head screw driver youpush the little clip up while pulling on the nob. it will come off with some effort.
2. you will need your tork screw drivers to remove the front of the cluster.
2a. after removeing these this should come off.
3. now remove the 4 black tork screws around the piece
4. so now your dealing with this.
4a. start to pull it out from the bottom but be careful because there are two plugs connected in the back.
4b.remove them. one one the left and one on the right.
5. now its out.
6. on the back you will see the 6 brass tork screws.
remove them!
7.now heres the circut board.
pull strait up on the odometer plug
then pull off the circut board.
8.
now its off.
9.now remove the two screws of the odometer circut board with a smaller tork screw driver.
now simply replace all YOUR circutry on the cobra cluster like so. put your odometer board on then the circut board and white backing.
10. now after youve put all your hardware on the cobra cluster it should be complete
11. now put it back in the way you removed the old one. reconnect the battery and try starting it. this is where EVERYONE says the PATS system wont let you start the car. well they are wrong! mine started right up and kept the same mileage!
it also looks good at night!
hope this helps someone!
oifdoc is offline   Reply With Quote
Old 02-14-2011, 05:56 PM   #2
1ijack's Avatar
Send a message via Yahoo to 1ijack
I just did that today. Here is what I did to mine. I changed bulbs with LEDs now it is so bright. Great mod. Thanks for the process u beat me to it.
Easy mod. I like the white gauges.
ID:	23553   Click image for larger version
The Mustang Mafia
"Join the family, if you dare"
www.themustangmafia.com
1ijack is offline   Reply With Quote
Old 02-14-2011, 07:17 PM   #3
Re: cobra dash cluster swap!
Very nice writeup! PM Brent and see if he can put this in the tech article section!
93CobraGuy is offline   Reply With Quote
Old 02-14-2011, 07:39 PM   #4
Titus Wadicus
svtlx's Avatar
sooo this is for 99-03 ppl right?
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-14-2011, 07:54 PM   #5
00STANG00's Avatar
Send a message via AIM to 00STANG00 Send a message via Yahoo to 00STANG00
looks like it
SUCK MY DUST
00STANG00 is offline   Reply With Quote
Old 02-14-2011, 07:56 PM   #6
Rosco's Avatar
Great write up. The step by step with pictures made it clear
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 02-14-2011, 09:21 PM   #7
sorry man! yours looks nice though!
Old 02-14-2011, 09:22 PM   #8
whos brent?
Old 02-14-2011, 09:23 PM   #9
99-04 its all the same. if you need anything just pm or reply!
Old 02-14-2011, 09:24 PM   #10
thanks alot man! i tried to make it as easy as posible for everyone!
Old 02-14-2011, 09:26 PM   #11
Originally Posted by oifdoc View Post
whos brent?
He's the site owner. This would be something good for the tech article section. I'll PM him with a link.
Old 02-14-2011, 09:31 PM   #12
thanks! im kinda new to this site!
Old 02-14-2011, 09:44 PM   #13
You're good. He will probably PM you now.
Old 02-14-2011, 09:59 PM   #14
Titus Wadicus
svtlx's Avatar
thank you very much, but i meant the write up... i saw the digital odometer and no speedo cable plug in...so i assumed it was 99-03 dash write up
Old 02-15-2011, 06:07 AM   #15
yeah 99-04
Instrument cluster swap ponyboy94 Pre-2005 V6 Mustang 17 09-28-2010 06:09 AM
FS: 2003 cobra gauge cluster. Trades too 99MustangGTman Mustang Parts for Sale and Wanted 6 06-27-2008 04:21 PM
cluster swap pipeguy 1996-2004 Mustang GT 9 05-08-2008 10:41 AM
instrument cluster swap pipeguy General Mustang Discussion 0 04-11-2008 09:43 AM
v-6 to cobra swap jimmy_beaner 1996-2004 Mustang GT 30 08-11-2005 08:38 PM
12:13 AM
