Question for you forced induction guys... - Mustang Evolution
Old 02-15-2011, 07:23 PM   #1
outlawfrog's Avatar
I realize that intercoolers help out alot with forced induction, but would one benifit an N/A car? May be a stupid question, but I was curious.
1996 GT, 5-speed, Moonlight Blue, Opal Gray leather, Flowmaster Cat-Back exhaust (Delta 40 series), BBK cold air intake & 75mm TBI, Super Chips programmer.
Originally Posted by 67mustang97 View Post
outlawfrog is probably right
Originally Posted by outlawfrog View Post
I might pull an "osirisguy", and make that my new sig quote!
outlawfrog is offline   Reply With Quote
Old 02-15-2011, 07:37 PM   #2
Not really. Cai is cool enough. Heat builds up when you compress air. N/a doesn't really have that issue.
Alscobra is offline   Reply With Quote
Old 02-15-2011, 07:40 PM   #3
outlawfrog's Avatar
Re: Question for you forced induction guys...
Ok! Thanks bud. Like I said, I was just curious if there would be any benefit. Still thinking about an intake plenum, and wasn't sure if there was anything else I could do to help out with the airflow.
Old 02-15-2011, 07:45 PM   #4
The cooler the air in a n/a is better though. Fenderwell cai setup works to keep engine bay heat out.
Old 02-15-2011, 07:47 PM   #5
outlawfrog's Avatar
Yea, I have that covered. Just considering what other bolt-ons I wanna go with, just to squeeze-out a little more kick, without spending a fortune..lol
Old 02-15-2011, 10:49 PM   #6
Titus Wadicus
svtlx's Avatar
you got gears?
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-15-2011, 10:54 PM   #7
outlawfrog's Avatar
Nope....just the stock crap. Not able to sink that kinda cash into it right now.
Old 02-15-2011, 11:14 PM   #8
Titus Wadicus
svtlx's Avatar
well, like someone told me....you gotta pay to play....lol. dont feel bad, it took me years to buy all my stuff...
Old 02-16-2011, 07:14 AM   #9
they wont help on an N/A car, only helps on a supercharged application as compressed air is hot and needs to be cooled down.
Old 02-16-2011, 10:48 PM   #10
outlawfrog's Avatar
Your Termie still gives me wood! lol
Old 02-16-2011, 10:59 PM   #11
A plenum would help. On the new edge models that is the most restrictive part of the intake system. A bigger tb does help too however with both mods don't expect major gains,10 hp tops. These mods do help throttle response tho. Mine seemed to pick up a lil quicker,no lag. Do you know if your car has pi heads. If not that should be your first mod. Pi heads on a non pi motor is good for 70 hp once you factor in the increased compression ratio. And pi heads can be had for 200 bucks and they are am easy bolt on. Make sure you have an afternoon to dedicate to it and if it's your Dd make sure you have all the parts
Old 02-17-2011, 12:50 AM   #12
outlawfrog's Avatar
Yea Everett, I already have a BBK 75mm Tb on it, and I'm just waiting on permission from the wifey for the plenum...ahahah.
Actually, I'm kinda in the middle of what I want to do. I can get either the stack or c&l plenum....or a set of 3.73's for close to the same price. The plenum, I could easily do myself, but I'd have to have some major help with the gears, which I have a buddy that works at the other "O" store that'd help me out with that. He's also found PI heads at salvage yards for around 200 bucks, then add in a PI intake, it's just a tad too much for the crap pay I'm getting right now. lol Basically, I'm trying to get all of the least expensive stuff done first.
Old 02-17-2011, 12:56 AM   #13
Well with the mods you have there you will have close to 270ish to the wheels. With a 5 speed and drag radials you could get down the 1320 in 13.8 if you slip the clutch at 5000 rpm. You have a good list there. I have basically same but I have 3.90s and nitrous. I spray 75 on the street and 175 on the track with meth I might add. It's zex tho so they are over-rated by about 10%. Good luck with your mods. You will fall in love with your car all over again.
Old 02-17-2011, 01:00 AM   #14
outlawfrog's Avatar
Yea....I'm still loving it! Got ALOT that I WANT to do to it. Unfortunately, if I decide to take it down the track, I'll have to sneak away to do it! LOL The first words out of the wifey's mouth was "You don't need to take it to the track! It's too dangerous, and we can't afford to fix it!" hahahaha
Old 02-17-2011, 01:09 AM   #15
She is right however there are worse things that cost more that us boys get up to that are "fun" too
Old 02-17-2011, 01:15 AM   #16
outlawfrog's Avatar
Here's another question, on the fitment of the plenums. Will the still fit with the strut tower brace? Most of the "customer images" on AM have no tower braces, and I notice mine is already pretty damned close.
Old 02-17-2011, 01:23 AM   #17
My pp plenum is about a half inch taller than the stocker
Old 02-17-2011, 01:31 AM   #18
outlawfrog's Avatar
EWWW.....that puts it REAL close to the tower brace. Errr....well, I just looked again. The only thing I think I'd have to worry about clearing, is the CAI tube, which I may be able to just turn down a little more, and MAYBE the IAC valve.
I'd thought about the PP plenum, also.....UPR has it for 99 bucks, vs the stack or c&l for 134 at AM.
Old 02-17-2011, 01:36 AM   #19
It's a really nice piece. And a great value at that price
No forced induction. GunMetalBullet 2005-2010 Mustang GT 30 12-29-2010 09:06 PM
Where to buy forced induction iwannagofast Pre-2005 V6 Mustang 3 06-12-2008 07:41 AM
158k motor hold forced induction? powerhungry966 1979-1995 Mustang GT 10 10-10-2006 01:18 PM
Road to Forced induction Drunken Ghost Pre-2005 V6 Mustang 8 08-17-2006 09:16 AM
Exhaust in correlation to forced induction Drunken Ghost Pre-2005 V6 Mustang 1 08-02-2006 08:21 PM
03:14 PM
