Smokeing only after hard down shifting - Mustang Evolution
Old 02-17-2011, 09:53 PM   #1
So I just re did my heads and a few other thing but b4 I blew a head gasket I did not have any smoke at all now when I down shift pretty hard like up around 4k when I come to a stop and give it a little gas it smoke does any one have a idea what could make this happen I have always herd it is a valve problem when it does this but not sure oh and the smoke is a blueish tent and has a oil smell to it and I also could use a tune but I would think that would make 4 a all around problem sry I'm kinda jumpy in my writing but it should make since lol
Sick01cobra is offline   Reply With Quote
Old 02-18-2011, 09:42 AM   #2
stampde's Avatar
Re: Smokeing only after hard down shifting
sounds like valve seals to me
2011 GT Auto
Old 02-18-2011, 10:30 AM   #3
Titus Wadicus
svtlx's Avatar
when u say u re-did your heads...exactly what did you do? and what did you disassemble?
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-18-2011, 10:34 AM   #4
stampde's Avatar
i think he just replaced the head gasket ??
2011 GT Auto
Old 02-24-2011, 01:40 PM   #5
So it only smokes when you down shift? No smoking when you start it up in the mornings?
Twinturbostang is offline   Reply With Quote
Old 02-24-2011, 01:46 PM   #6
Did you install the heads or did a mechanic shop do the work? Did you have them machined by a head shop? Sorry to ask these questions I'm just trying to tell you were you went wrong. Theses 4.6 heads are a pain in the rear and very hard to install properly .
Old 02-24-2011, 02:09 PM   #7
Valve guides are shot
Shifting Problems dino.999 Pre-2005 V6 Mustang 0 02-12-2011 01:09 PM
shifting problem? black bullet 1979-1995 Mustang GT 10 12-18-2010 03:01 PM
4th to 5th shifting issue and hard as hell get into R - Black_Sunshine Pre-2005 V6 Mustang 7 03-18-2010 09:55 AM
Shifting problems blue-saleen Pre-2005 V6 Mustang 4 09-08-2009 07:55 PM
Shifting feel KyleUSAF Pre-2005 V6 Mustang 6 02-15-2005 10:28 AM
08:21 PM
