What next? - Mustang Evolution
Old 07-21-2007, 08:52 AM   #1
ridenmystang's Avatar
What next?
Ok so far motor wise and exhaust this is what I have:
MOTOR MODS:
Diablo Predator Programmer
K&N Air Intake
BBK Throttle Body 75 MM
Throttle Body Spacer
Power Plus Plenum
Plenum Spacer
EXHAUST:
MAC Ceramic Coated Long Tube Headers
Flow Masters 40 Series
BBK Xpipe
No Cats
102 Dollar tips
What should be my next step? 373's? pullies? or what?
One wicked 03 GT FOBRA
ridenmystang is offline   Reply With Quote
Old 07-21-2007, 09:02 AM   #2
wiarumas's Avatar
Re: What next?
id go gears and a nice tune to go with it.
pullies first... but that is relatively cheap.
Old 07-21-2007, 09:12 AM   #3
hottcobra's Avatar
Re: What next?
I'd do UDPs, dyno tune, & 4:10 gears. Don't fear the gear
Old 07-21-2007, 10:26 AM   #4
Re: What next?
Supercharger.
JROC is offline   Reply With Quote
Old 07-21-2007, 10:30 AM   #5
bbunt302's Avatar
Re: What next?
Gears. 4.10s if you have an automatic or 3.73s for a five speed.
Scary stuff.
Old 07-21-2007, 10:44 AM   #6
95&modified's Avatar
Re: What next?
Sounds good so far. Welcome from another noob!
95&modified is offline   Reply With Quote
Old 07-21-2007, 06:23 PM   #7
Thomas91169's Avatar
Re: What next?
GEARS!
Riden i almost bought a set of gears last week, then remembered "Dammit, i dont have a programmer!"
get some 3.90's or 4.1's and thatll pep that summa***** right up.
then start saving for a blower and support......:drool:
-Thomas-
Old 07-22-2007, 08:11 AM   #8
Re: What next?
I was planning on getting 4.10's but someone said 373's would be better. Whats the diff? Oh and I do have an automatic
Def not a noob
Originally Posted by Thomas91169 View Post
GEARS!
haha I hava yo programmer! Im glad I got it. What did you have your shift pressure set at? Im scared to tinker with the pressure because Im thinking it could mess my transmission up. And Im def saving for a supercharger
Old 07-22-2007, 01:30 PM   #9
wiarumas's Avatar
Re: What next?
4.10 for auto
3.73 for manual
gears dont add horsepower... the basically make you accelerate faster. so basically 4.10s accelerate faster than 3.73. its all preference, but the fact that autos dont shift make 4.10s more preferred than 3.73s.
Old 07-22-2007, 01:54 PM   #10
Re: What next?
Originally Posted by wiarumas View Post
4.10 for auto
3.73 for manual
Torque Multiplication my friend.....
and yes, most definately 4.10's minimum for a auto. although due to the increased and constant rpm's the transmission will be under, an external cooler is a must to ensure longetivity of the tranny.
i have a manual so no shift pressure crapola for me. have fun with the diablo, have you adjusted timing or fuel yet? i maxxed out the timing on mine and that gives you a noticeable change up top, however i did it in weekly increments and in winter i put it back down to stock because of the crap winter blends in gasoline.
-Thomas-
Old 07-23-2007, 07:53 AM   #11
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Re: What next?
Messing with the shift pressures is fine. It's almost just like putting a shift kit in it. A firmer shift = a faster shift which creates less friction. Friction = heat which = po'd transmission. I have all my points on maximum firmness.
DarkShadow is offline   Reply With Quote
Old 07-23-2007, 07:55 AM   #12
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Re: What next?
4.10 rear-gears are a bit much for an auto, imho. I'd rather not have a car that's geared like a tractor.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 07-23-2007, 09:16 AM   #13
Re: What next?
So it wont mess up my transmission shifting so hard? I always thought it would. My bf has replaced his trans 5 times in his yukon. He has all kinds of performance stuff done to it. We were thinking it was because his 2nd shifted so freaking hard that it messed his trans up everytime And he doesnt have a shift kit its just how he had it programmed
Old 07-23-2007, 09:51 AM   #14
Y2E0L0L5OGWT's Avatar
Re: What next?
lol his first mistake was doing that to a yukon!!! jfwy
Old 07-23-2007, 11:32 AM   #15
Herbstang's Avatar
Re: What next?
4:10's for the auto !!! If your really gonna go S/C You'll want your stock crank pullie
Old 07-23-2007, 12:06 PM   #16
hottcobra's Avatar
Re: What next?
What you need to know is that yes turning up your line press. will help with less slip in the clutch packs and lower trans. temps. BUT if you increase the line press. too much. you can start the break hard parts like the output shafts or sunshell and what not. this is the most common trans failure in performance trans setups. a good rule of thumb is that it should only bark the tires at wide open throttle. ONLY bark the tires NOT spin the tires. no matter how much horsepower you have. so you need less line press. with more hp.
Old 07-23-2007, 12:55 PM   #17
Send a message via MSN to 1996stang Send a message via Yahoo to 1996stang
Re: What next?
4.10 gears and a 125 shot and don't look back.
unless your looking for the ls1 boys
2004 mach 1 stock and staying that way.
1996stang is offline   Reply With Quote
Old 07-23-2007, 05:01 PM   #18
bullitt482's Avatar
Re: What next?
Tell him to put in a built 4l65 or something other than that crap 4l60. That should solve it.
01 Bullitt
Old 07-23-2007, 05:07 PM   #19
bbunt302's Avatar
Re: What next?
Originally Posted by Guy That Doesn't Have a LS1 Anymore (Maybe it was Marvin???)
4.10s were made by God to make your heads nod.
Scary stuff.
Old 07-23-2007, 07:38 PM   #20
rydog's Avatar
Send a message via MSN to rydog
Re: What next?
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 07-23-2007, 08:28 PM   #21
Re: What next?
He has 4L65E in it already. The only diff bet the 2 is there is a center bolt at the top of the sunshell on the 4L65E right?
Old 07-23-2007, 08:30 PM   #22
hottcobra's Avatar
Re: What next?
I think it also has an extra clutch and steel in each clutch pack
04:35 AM
