Mustang cranks but doesnt start - Mustang Evolution
Old 02-21-2011, 07:21 PM   #1
Jamesgt08's Avatar
I have a 2000 gt with a 4.6. It cranks but doesnt turn on. I changed my fuel filter then started it then it smoke a little then died out. Im thinkin it could be the fuel pump or am i wrong?
Jamesgt08 is offline   Reply With Quote
Old 02-21-2011, 09:45 PM   #2
ColeJohnson's Avatar
Re: Mustang cranks but doesnt start
If the fuel pump is out then it wouldn't start at all. First thing I would check is the battery or spark plugs. That's simple. Then you can work on figuring out if it's the pump or not.
Old 02-21-2011, 10:08 PM   #3
Jamesgt08's Avatar
Brand new battery and brand new spark plugs brand newfuel filter. Now what??
Old 02-21-2011, 10:09 PM   #4
Jamesgt08's Avatar
Battery is fine. It wants to start but never turns over. Just keeps cranking thats all.
Old 02-21-2011, 10:12 PM   #5
It ran before you put the fuel filter in, right. Then you replaced it and tried to start the car?
Try turning the key on and off several times with a few seconds pause while it's on. This is recommended to do after the fuel system has been de-pressurised. Then try cranking it.
93CobraGuy is offline   Reply With Quote
Old 02-21-2011, 10:14 PM   #6
Jamesgt08's Avatar
No the night before it ran just fine. The next day it didnt start at all. So i changed my filter then it started fine but then i started giving it gas and it started dieing out. Andafter that it never start again just cranks.
Old 02-21-2011, 10:15 PM   #7
I had that problem before... I'm trying to remember what we did to fix it. If I remember, I'll be sure to PM you.
Old 02-21-2011, 10:21 PM   #8
Jamesgt08's Avatar
Ok thanks. Try to remember.
Old 02-21-2011, 11:24 PM   #9
Jamesgt08's Avatar
Old 02-22-2011, 01:56 PM   #10
I think all that was wrong with mine was that the battery was going bad and the terminals were corroded and it wasn't getting a good connection.
I can't remember anything else being the matter.
When my fuel pump was going out, it would run for a time then randomly die. And whenever the pump finally died, it wouldn't crank, it'd just turn over.
2016 Comp Orange GT (current)
Old 02-22-2011, 04:23 PM   #11
SaleenFiend's Avatar
Spark? Fuel? Air? There are way too many things. We are just shooting in the dark. You need to have a mechanic look at it.
Old 02-22-2011, 07:21 PM   #12
I agree.
Old 02-22-2011, 07:39 PM   #13
Supersnake4.6's Avatar
Have you check the ignison relay
Supersnake4.6 is offline   Reply With Quote
Old 02-22-2011, 07:48 PM   #14
Jamesgt08's Avatar
Where is that located at?
Old 02-23-2011, 08:54 AM   #15
Pintobeanracer's Avatar
Try checking the mass air flow sensor. Maybe it just came lose or it's starting to come unplugged.
Pintobeanracer is offline   Reply With Quote
Old 02-24-2011, 02:13 PM   #16
I would try the crank postion sensor on the side of the block. Are there any codes stored in the computer?
Twinturbostang is offline   Reply With Quote
Old 02-24-2011, 02:16 PM   #17
Also have a friend tap on the gas tank with a hammer while you try and start it . If it runs with him hitting the tank then you have a fuel pump issue. The float inside the pump gets stuck and sometimes this will work.
Old 02-24-2011, 02:25 PM   #18
stampde's Avatar
do you hear the fuel pump pressure up when you turn on the key ,b4 you crank it ??
2011 GT Auto
Old 02-24-2011, 03:11 PM   #19
It's fuel or spark
Old 02-25-2011, 09:54 AM   #20
Jamesgt08's Avatar
I changed out my MAF sensor and it started up and it was smokin not really bad tho. I let it run for a bit then it sounded like it was gonna die so i gave it a little gas when i did that it just died. Now i cant start it again :/
Old 02-25-2011, 10:35 AM   #21
stampde's Avatar
i 'm thinkin fuel pressure dude
2011 GT Auto
Old 02-25-2011, 10:51 AM   #22
Jamesgt08's Avatar
So like the fuel pump?
Old 03-12-2011, 06:48 PM   #23
Jamesgt08's Avatar
I finally changed my fuel pump and my car works now so excited i can drive my stang again.
Old 03-13-2011, 12:22 AM   #24
I am happy it was an easy fix. Get in er and drive
Built 2 Last TTT
Old 03-13-2011, 10:31 AM   #25
Jamesgt08's Avatar
Yea i was drivin her for a while. Everything is back to normal.
1966 Mustang Where do I start? DanRidesaPONY Classic Mustangs 6 01-03-2011 06:11 PM
Mustang Won't Start Please Help brad12 1979-1995 Mustang GT 7 04-15-2010 09:35 AM
1995 GT cranks but no start hot 89beretta 1979-1995 Mustang GT 9 07-26-2009 09:23 PM
Travis Barker Cranks This n8r Pictures and Videos 9 10-16-2007 10:32 PM
my 3.8 2001 mustang won't start sahba22 Pre-2005 V6 Mustang 7 01-19-2004 04:21 PM
12:13 AM
