Locked motor - Page 2 - Mustang Evolution
Old 02-26-2011, 09:34 AM   #36
I dint know that the 00-04 were automatically dohc I'm ganna have to jump on that the I guess I can put pi heads cams and exhaust I can do later on ok one to find a 4.6 dohc
Itzmehotsauce is offline   Reply With Quote
Old 02-26-2011, 09:48 AM   #37
ibleedblue65's Avatar
5.4 is a direct bolt in. I repeat direct bolt in hell don't even tell the shop its a different motor.
ibleedblue65 is offline   Reply With Quote
Old 02-26-2011, 09:50 AM   #38
You can pull the heads later on to port abs polish. Get a truck 5.4 some pi heads, a 5.4 intake and bolt it in. I'm serious here, it is just a ready to bolt a 5.4 back in as a 4.6. Do not go dohc, a lot more work. Stay 2v, you can make plenty of power that way.
Old 02-26-2011, 09:53 AM   #39
I can get you some pi heads. We have several sets laying around. Shoot me a pm and I can help you with all if this.
Old 02-26-2011, 09:54 AM   #40
ksrumbel's Avatar
00-04 aren't automatically dohc. The cobras and Mach 1 run dohc. I'm not sure what involves swapping to a 4.6 dohc. The 00-04 sohc will be your easiest route. Throw some cams and heads on it and you will have a fun ride
ksrumbel is offline   Reply With Quote
Old 02-26-2011, 09:57 AM   #41
I don't want you guys to think I'm waiting your time or anything cuz I'm also doing my own research everyone u guys give me information but I hit another road bump . That 4.6 dohc is a 32 valve you guys are saying that that engine would fit in perfectly without having to change the harness or computer or mounts? Because if I can recall my original engine only pushed 215 horses these dohc engines are pushing between 275 and 320 depending on which car I get it from so I'm curious on how it could all just be plug and play
Old 02-26-2011, 09:59 AM   #42
Not direct bolt in. do what I said to.
Old 02-26-2011, 10:00 AM   #43
I just read this so u say a truck 2 valve 5.4 engine is my best bet no hitting the hood no modifications or nothing. And that type of engine comes off of like an explorer or so right
Old 02-26-2011, 10:03 AM   #44
With the correct intake, no issues. This is how they should have built the mustang. The added torque is a blast.
Old 02-26-2011, 10:44 AM   #45
Lol that engine comes off of a truck or expedition its ganna make my pony a monster LOL
Old 02-26-2011, 10:54 AM   #46
Qwik Four Six's Avatar
No, the dohc isn't that complicated. But get a 5.4 then. They used that motor in the 2000 mustang cobra r.
Qwik Four Six is offline   Reply With Quote
Old 02-26-2011, 01:31 PM   #47
04greygt's Avatar
Re: Locked motor
now is the time to upgrade any performance mods you might want will be cheaper to install while replacing the engine
04greygt is offline   Reply With Quote
Old 02-26-2011, 02:13 PM   #48
Ok final question honest response. Should I just buy a 95 stang with the 5.0 in it already or try to fix this one lemme know fella cuz is rather just get my hands on the 5.0 and then I can put all the goodies into it
Old 02-26-2011, 02:19 PM   #49
The modular power plant is a better starting point than a 5.0. Keep the modular motor. The easiest way to go 5.0 would be with a donor car but it is a step down imo.
Old 02-26-2011, 02:24 PM   #50
People tell me skies the limit with a 5.0 but and since the 94 and 95 came with it already is probly be better off with it
Old 02-26-2011, 02:25 PM   #51
The block is the limit on a 5.0. Modular is better
Old 02-26-2011, 02:31 PM   #52
Re: Locked motor
I'd rather stick with the 5.0 pushrod. Tried and true aftermarket, easier to work on yourself, and it doesn't take a whole lot of money to make big power on them.
93CobraGuy is offline   Reply With Quote
Old 02-26-2011, 02:35 PM   #53
Modular s are easy to work on and there is a huge aftermarket. Been in mustangs since 96. The modular block design is far superior. This may just be because you are not comfortable with mod motors.
Old 02-26-2011, 02:43 PM   #54
Re: Locked motor
Probably just because I like to stick to what I know best. I've had OHC cars before, 4 cylinders, and I just found them to be a pain to work on sometimes.
Old 02-26-2011, 07:19 PM   #55
There's nothing wrong with that and I don't mean to bash. I own two small block powered cars. A 93 notch and a 65 with a 347. I love an old school pushrod, modular is just better.
Old 02-26-2011, 07:24 PM   #56
Re: Locked motor
Didn't take it as bashing at all. To each their own!
Locked thread error: MarkuzLS1 ME Site Help & Announcements 5 10-20-2005 12:09 PM
locked Gaston The Bar 4 02-22-2005 09:24 PM
Thread Split/Locked Autobadges.com The Bar 5 04-29-2004 05:19 PM
Will the PI be locked when im just cruising? greenflash00 Pre-2005 V6 Mustang 13 10-27-2003 08:29 PM
07:42 PM
