Rear End - Mustang Evolution
Old 02-25-2011, 07:46 AM   #1
Rear End
I was trying to show off the other day and lay down some rubber. But, only one tire spun causing me to look like an idiot. This has happened before on occasion. What is the reasoning behind this? I thought My GT had a limited slip rear end in her. Is this normal or is there something wrong with my rear end ?
Jdaddy42 is offline   Reply With Quote
Old 02-25-2011, 08:12 AM   #2
What year stang do you have? Ive heard this this happens a lot for New Edges in particular.
sno4life is offline   Reply With Quote
Old 02-25-2011, 08:26 AM   #3
ibleedblue65's Avatar
The clutches in the carrier are worn.
ibleedblue65 is offline   Reply With Quote
Old 02-25-2011, 08:29 AM   #4
Re: Rear End
02 GT
Old 02-25-2011, 08:32 AM   #5
Re: Rear End
Thanks for the info. I was thinking about changing the rear end with some 4.10's anyway might as well change the whole thing while I got it out
Old 02-25-2011, 08:39 AM   #6
You won't regret 4.10 gears. I want then myself.
I might do the 3.73s.
Old 02-25-2011, 09:36 AM   #7
stampde's Avatar
Re: Rear End
+ 1
2011 GT Auto
Old 02-25-2011, 10:08 AM   #8
Re: Rear End
yea the clutches are getting worn or you dont have the right fluid in there or to much friction modifier etc etc. It happens with old age.
Old 02-25-2011, 03:20 PM   #9
Beav's Avatar
Re: Rear End
lalayla,
I had 4.10's in one of my 05 GT's and I took them out, and put 3.55's back in... They whined and I didn't like the way it made first gear feel, almost truck like... And it didn't feel that much quicker..
3.73's might be fun though....
07 Roush 427R, Brembo 14" rotor and four piston calipers
05 GT Mustang, FRPP, FR X pipe, Hurst short throw,
American Racing Torque Thrust 10X20 wheels,
Granettelli tower brace, custom painted flat black grafix, Yellow Optima
Beav is offline   Reply With Quote
Old 02-25-2011, 04:16 PM   #10
cherrybomb's Avatar
Re: Rear End
Thanks for the advice, I've been weighing what gears to get myself.
cherrybomb is offline   Reply With Quote
Old 02-25-2011, 04:18 PM   #11
Re: Rear End
there isnt that much difference in 4.10 to 3.73 rpm increase wise, I think for the street with a normal ratio trans 3.73 is good, heck the 2011's come with them as an option but they do have a lower final drive in 6th but not by much.
Old 02-25-2011, 05:05 PM   #12
ksrumbel's Avatar
I have a 00 GT with 4.10s. One of the best mods I did. If the gears whine then fire your mechanic because he didn't shim them correctly. In fifth gear at 65 mph I'm tacking about 2400 rpm. And man do they rip when you get on it. I'm running 13.7s with basic bolt-ons and the gears. If you plan on a power adder eventually then i would go with 3.73s. You will run out of gear really fast with 4.10s and a blower
ksrumbel is offline   Reply With Quote
Old 02-25-2011, 06:17 PM   #13
I would just go with 4:30 gear from ford and be done . People will tell you that they have gone from this gear up to this gear and always seam to go up more . If you are planing on adding alot of power to car I would go ahead and just do the 4:30. 4.10 gears vs 4:30 gears is night and day
Twinturbostang is offline   Reply With Quote
Old 02-25-2011, 06:19 PM   #14
If your gears whinnef for any reason it's because of a bad install or you bought some ****ty gear. Exp: richmond gears
Old 02-25-2011, 11:15 PM   #15
Re: Rear End
Thanks for all the help guys.
Old 02-26-2011, 12:45 AM   #16
USAF_stang's Avatar
Re: Rear End
doing the 3.73 gears as well. Seems most practical in a DD to me.
Some how bet there was a chick involved lol
USAF_stang is offline   Reply With Quote
Old 02-26-2011, 06:25 AM   #17
Chick Nasty's Avatar
Send a message via AIM to Chick Nasty
Re: Rear End
ooo...started looking at this bc i thought we were talking about something else...lol Go with the 4.10s!!!
Chick Nasty is offline   Reply With Quote
Old 02-26-2011, 01:36 PM   #18
04greygt's Avatar
Re: Rear End
remember that the size of your tire depending on height can hurt or help your rear end ratio I have 3.73 and they were great with the stock 245/45/17 tires the I moved up to the 275/40/17 and it slowed me in the quarter mile but my hwy gas mileage piced back up
04greygt is offline   Reply With Quote
Old 02-26-2011, 01:40 PM   #19
Beav's Avatar
Re: Rear End
Gear whine is common with 4.10's, research it...
http://www.google.com/search?q=+4.10...ient=firefox-a
97 v6 rear end 97 stang Pre-2005 V6 Mustang 1 10-09-2008 10:22 AM
GT Rear end fasternu_674 Pre-2005 V6 Mustang 11 01-21-2008 04:41 AM
Rear End megax29 Pre-2005 V6 Mustang 8 08-27-2007 07:19 PM
New rear end? Pro501day Pre-2005 V6 Mustang 18 09-09-2006 09:55 AM
rear end v6stangracer Pre-2005 V6 Mustang 12 03-23-2005 09:41 AM
10:23 AM
