99 Cobra idling problems, help =( - Mustang Evolution
Old 03-02-2011, 11:54 AM   #1
I have no problems driving it or anything but when i pull it out of gear and cost to a light or a stop sign in neutral, it idles up to and around 1300 while im rolling and then when i come to a complete stop it goes down to 1000. sometimes, when i do come to a stop itll go up and down constantly between 900 to 1300. on a good day it will stay consistant at 1000. i feel like its affecting my performance, why is it doing this?
nasty99 is offline   Reply With Quote
Old 03-02-2011, 11:59 AM   #2
Re: 99 Cobra idling problems, help =(
well it can be a couple of things, I would start by cleaning my MAF sensor REALLY good especially if you have an aftermarket filter/intake that requires oil (and even more so if you have since oiled it) as gunk gets on it
After that the idle bypass valve (IAC) on the throttle body area, little round looking thing. Needs to be cleaned or replaced as it controls idle in neutral.
The final step if that is not solved it is the tune can adjust the idle decay rate (rate the rpms come down in neutral or after a rev) this can be adjusted.
Old 03-02-2011, 12:05 PM   #3
Yea my engine light went on about a year ago and it was for my IAC but I had gotten that replaced, well supposedly considering I don't go to that mechanic anymore cuz they are horrible. Anyways during the winter it would sometimes bog down and shut off on my first startup after a couple hours till I got that fixed. Then it eventually started doing it again and this winter it did it just like it was before I got that rreplaced. So I'm guessing MAF sensor?
Old 03-02-2011, 12:06 PM   #4
Gster's Avatar
What mods have u done? Kind of sounds like an air leak.
Gster is offline   Reply With Quote
Old 03-02-2011, 12:09 PM   #5
65mm tb, shorty headers, bbk xpipe, slp lm1 cat back, jlt cai.
Old 03-02-2011, 03:48 PM   #6
Gster's Avatar
Check to make sure u don't have a leak between your MAF and your throttle body.
Old 03-03-2011, 04:36 PM   #7
ksrumbel's Avatar
Happened to me. Replaced my IAC and it was fixed.
ksrumbel is offline   Reply With Quote
Old 03-03-2011, 04:40 PM   #8
Mine wasn't =( lol
95' Cobra SVT Problems xspektrex 1979-1995 Mustang GT 43 01-19-2011 11:42 AM
Tranny problems with my 97 Cobra Sparkdic 1996-2004 Mustang GT 0 04-28-2010 06:38 AM
Idling too low katie_ann 1996-2004 Mustang GT 9 09-02-2009 03:42 PM
Rough Idling greenmustang27 Pre-2005 V6 Mustang 2 05-14-2009 08:29 AM
1997 Cobra tranny problems oojdbozoo 1996-2004 Mustang GT 5 05-13-2009 12:57 AM
10:30 AM
