Best way to remove stock h-pipe passenger side bolts? - Mustang Evolution
Old 03-04-2011, 06:28 PM   #1
jjsg09's Avatar
Can't remember how the best way to go about removing the passenger side two bolts on the stock h-pipe!
Old 03-04-2011, 06:42 PM   #2
hottcobra's Avatar
Impact, long extension, and penetrating oil
Old 03-05-2011, 07:37 AM   #3
Loc: Austin,TX
Re: Best way to remove stock h-pipe passenger side bolts?
You said.........penetrating.
Old 03-05-2011, 03:21 PM   #4
jjsg09's Avatar
I'm afraid the impact will round the bolt off off I dont have it secured on there well enough.
Old 03-05-2011, 10:04 PM   #5
04machazblue's Avatar
Be careful I would spray that bastard a couple times hot and cold I broke mine not fun to drill
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 03-06-2011, 12:21 AM   #6
jjsg09's Avatar
I got the whole thing off in an hours worth. The key to it wasn't and impact.....2 wobble extensions fit right on both of them just perfect and a breaker bar. Wam-bam-thank-you-mam
Passenger Side Headlight Goes out. GT_Miami 2005-2010 Mustang GT 12 07-07-2015 12:30 AM
Need pics of vacuum lines passenger side Tincup7 Pre-2005 V6 Mustang 3 02-09-2011 09:02 AM
passenger side door rattle buzz8907 Mustang Audio & Video 8 08-31-2010 09:50 PM
Passenger side rear end squeak?? SuperDave2010 1996-2004 Mustang GT 4 03-09-2010 01:18 PM
Passenger Side Power Window Not Working louie7600 General Mustang Discussion 1 07-27-2008 07:36 PM
08:00 PM
