Transmission help please, yikes! - Mustang Evolution
Old 03-05-2011, 06:40 PM   #1
Hey everyone, i have a 96 gt conv with a modded motor, supercharged etc.. With a aode tranny and b&m ratchet shift kit. Today, I took the car out and noticed a lag in the shifting to start.. And then I couldn't shift it in to 2nd, it would just rev but if i shifted again it would go into 3rd... The tranny has the manual shift mechanism in it so the tranny can only be used by manual shifting. When I bought the car about a month ago... It had receipts of the tranny being completely torn down rebuilt in feb 2010. When I got home I looked under the car and I could notice it was leaking tranny fluid right where the tranny is connected to the block... I'm assuming. I also noticed a little tranny residue on the end of the tranny...Anyways, I'm a little bummed of what could be the problem and mostly how much it will cost! Could it be a blown seal, etc?? Any help would be really appreciated. I checked the Dipstick and it is reading full and the fluid Is the color is should normally be.
Thanks
Ts281 is offline   Reply With Quote
Old 03-05-2011, 07:59 PM   #2
Re: Transmission help please, yikes!
Could be the transmission seal and or gasket at the front of the transmission or the seal on the converter leaking. Either way not a big fix but time consuming by taking the transmission out to replace the seals .If you have to remove the transmission you might as well replace both seals. The front seal (or gasket) and the converter seal (s)
Jdaddy42 is offline   Reply With Quote
Old 03-05-2011, 08:13 PM   #3
I'd say a valve body problem. If you don't plan on racing it all the time i would put the stock valve body back in and just install a shift improver kit. JMO
Straublittleman is offline   Reply With Quote
Old 03-05-2011, 09:31 PM   #4
[QUOTE=Straublittleman;845157]I'd say a valve body problem. If you don't plan on racing it all the time i would put the stock valve body back in and just install a shift improver kit. JMO[
What do you mean when u say valve body?
Old 03-05-2011, 09:38 PM   #5
[QUOTE=Ts281;845183]
The valve body is in the trans at the bottom where the filter goes and it controls the shifting. It has about 40 bolts that hold it in there so I would have a mechanic do the change over.
But it could be as simple as the 2nd shift solenoid went bad and can be replaced by a trans shop for cheaper than another trans.
T-5 transmission jms69stang 1979-1995 Mustang GT 4 11-15-2009 01:37 AM
What transmission do I have???? 1silverstang Pre-2005 V6 Mustang 2 08-26-2006 06:36 AM
Yikes! Watch out for the wings.... Brent The Bar 25 04-26-2005 05:19 PM
Transmission Question: 1997 V6 Automatic Transmission ?? svtmustang88 Pre-2005 V6 Mustang 4 12-09-2003 04:49 PM
Transmission vigiracer Pre-2005 V6 Mustang 2 07-20-2003 01:47 PM
11:51 AM
