02 Gt Stalling coming to a stop - Mustang Evolution
Old 03-05-2011, 08:07 PM   #1
doubletap4311's Avatar
Okay, here is what is going on. I usually drive my car hard. It's a weekend vehicle only. While driving today, normal driving, I exited the freeway. I was slowing down, pushed in the clutch, waiting to come to a complete stop at the light. My car was still rolling about 20 mph, engine stalls! It did this same thing four times today, same situation. I was able to pop the clutch to restart and gain my steering and power brakes. I had a custom tune from AM a few weeks ago. i initially had an issue with the launch rpm setting, but they corrected that. I have never had this problem and am not really sure what is going on. Any ideas where to look? No check engine light on at all after the restart, only when it dies.
doubletap4311 is offline   Reply With Quote
Old 03-05-2011, 09:15 PM   #2
jjsg09's Avatar
Had the same thing a year ago in my 01 GT it's the idle air control valve, carbon corrosion builds up on the plunger so when you're car goes to idle ( disengaging your clutch ) it try's to open back up to keep the engine alive and it doesn't because it's all gunked up. Just take it off and clean it out with carburetor cleaner real well and you should be good as new. Don't buy a new one they are $50 or more and it's not going out just needs cleaned.
Old 03-05-2011, 09:23 PM   #3
Re: 02 Gt Stalling coming to a stop
Thanks for the quick response. I will try to clean it in the morning and see if that corrects the problem.
Old 03-06-2011, 12:26 AM   #4
jjsg09's Avatar
Hey no problem, if that doesn't help ya at least you might be avoiding another problem down the road.
Old 03-07-2011, 07:16 PM   #5
It was the iac. Cleaned it and it helped. Replaced it and it completely took care it.
2002 Gt, 5 speed, BBK Cai, BBK 78 MM intake plenum combo, steeda UDP, steeda tri axe shifter, 4.10 Ford racing gears, Sct custom tune, raptor shift light.
Old 03-07-2011, 09:26 PM   #6
jjsg09's Avatar
Hey awesome I hate those things when they go bad. I've had so many people have the same problem in a lot of cars and they think they have an engine problem when it's just a simple fix. Glad to hear the Stang is doing better.
03 GT engine stalling midgeorgiastang 1996-2004 Mustang GT 5 02-22-2008 05:38 PM
stalling 5.0 vil8er New Member Introductions & Greetings 0 02-16-2008 02:12 PM
Car Stalling megax29 Pre-2005 V6 Mustang 7 01-26-2007 09:46 AM
stalling 94 gt wmustanggt 1979-1995 Mustang GT 8 07-02-2006 01:13 PM
stalling on startup Deadmeat101 Pre-2005 V6 Mustang 4 09-16-2003 07:00 PM
06:36 AM
