03 GT...another problem - Mustang Evolution
Old 03-06-2011, 01:02 PM   #1
Zebs5408's Avatar
started her up the other day when i got off work and for the first time the belt started whining..... Not horribly loud but i could hear it from inside the car..i stop at auto zone on the way home and got some belt lube...it actually got louder when i applied it then it stopped..but when i got him it started again...now today when i cranked it the same whine was happening so i applied and it stopped for just a min...when im driving at low speed i can hear it but when im bout 40 mph it goes away....it make my car sound horrible...what do u guys think might be the problem...am i applying the lube wrong or something lol
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 03-06-2011, 01:14 PM   #2
Stop using the belt lube. Replace the belt. It's possible that a pulley or accessory is binding. A good trick to a belt squeal is black rtv. Put a little dab on each side of the belt. Smooth it out with your finger. Start and run it before the rtv cures. Hope this helps.
Alscobra is offline   Reply With Quote
Old 03-06-2011, 03:52 PM   #3
Zebs5408's Avatar
Re: 03 GT...another problem
sorry for being slow but explain "rtv" please and where can aquire it...i apperciate the info bro
Old 03-06-2011, 03:53 PM   #4
Auto parts store. Black silicone rtv sealant. Small tube. Don't take much. That's usually last ditch effort.
Old 03-06-2011, 03:55 PM   #5
What brand belt is on it? If it's goodyear gatorback. Replace it with something else.
Old 03-06-2011, 05:26 PM   #6
DarkShadows's Avatar
Explain how the RTV helps, I've never heard that one before.
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 03-06-2011, 05:31 PM   #7
If it was me, I would just replace the belt. If it still makes noise, which I doubt it will, then something is out of whack with the pulleys.
93CobraGuy is offline   Reply With Quote
Old 03-06-2011, 06:19 PM   #8
It just lightly coats the belt. Just a trick we always used at the dealer. Leave it running for a while and it will coat the whole belt. Really works.
Old 03-06-2011, 07:43 PM   #9
I know this sounds stupid but it is here for thought. I also had a whine on my belt awhile ago. I tried the lube and everything else. But to no avail it didn't work. I finally found out it was the bearings in the alternator that went bad. I changed the alternator and all was fine. Not saying this is your problem but it is here for thought in case the new belt still whines....
Jdaddy42 is offline   Reply With Quote
Old 03-06-2011, 07:51 PM   #10
jjsg09's Avatar
I had same problem, I changed all the idle pulleys and no difference in a whine noise. Put a brand new belt on it and never heard the whine again. I used gatorback belt.
Old 03-07-2011, 07:33 AM   #11
could be the belt or a bearing in an idler perhaps, if the belt has miles on it might as well replace it to find out.
97 A/C problem phaw16 1996-2004 Mustang GT 7 07-20-2009 12:39 PM
Got a problem need some help... 1234 1996-2004 Mustang GT 10 03-04-2009 01:13 PM
Got a little problem... Ibanezplayer272 Pre-2005 V6 Mustang 10 10-20-2004 08:17 AM
Help! Serious problem. Laser02 Pre-2005 V6 Mustang 9 07-19-2004 12:52 PM
07:08 AM
