Rpm drop - Mustang Evolution
Old 03-07-2011, 06:28 PM   #1
alexak187's Avatar
Region: Arkansas
Rpm drop
Alright iv had my stang for a while and havent really had any major issues. The only thing that it does and i cant understand why is when im driving and come to a stop the rpm drops to the point where it almost turns off. Its never actually turned off untill last night when i was stoped at a light. So any ideas on why its doing that and how do i go bout fixing it.
alexak187 is offline   Reply With Quote
Old 03-07-2011, 06:31 PM   #2
Gster's Avatar
TPS?
Gster is offline   Reply With Quote
Old 03-07-2011, 06:36 PM   #3
alexak187's Avatar
Region: Arkansas
[QUOTE="Gster"]TPS?[/QUOTE
Old 03-07-2011, 06:39 PM   #4
Gster's Avatar
Throttle position sensor
Old 03-07-2011, 06:41 PM   #5
alexak187's Avatar
Region: Arkansas
Oh you know how do i check that
Old 03-07-2011, 06:43 PM   #6
Mine fluctuated like that til I seafoamed it. All fixed for 5 bucks
Built 2 Last TTT
Old 03-07-2011, 06:49 PM   #7
Gster's Avatar
You can get a voltage meter and check it but there not expensive and really easy to replace. If it doesn't work your only out 20 bucks, but tps's go out quite often.
Old 03-07-2011, 06:53 PM   #8
Gster's Avatar
Built 2 Last TTT
Not many people live in a place where it gets 100 below zero, so everybody dosn't need sea foam. Lol.
Old 03-07-2011, 06:54 PM   #9
Seafoam cleans carbon and sludge. Great stuff...and it's only 100 below 0 for 6 months a year. It gets warm for a little while. A couple weeks in august
Built 2 Last TTT
Old 03-07-2011, 07:04 PM   #10
doubletap4311's Avatar
Idle air control. Pull it and clean it or
Replace it. Mine was doing the same thing this weekend.
2002 Gt, 5 speed, BBK Cai, BBK 78 MM intake plenum combo, steeda UDP, steeda tri axe shifter, 4.10 Ford racing gears, Sct custom tune, raptor shift light.
doubletap4311 is offline   Reply With Quote
Old 03-07-2011, 07:22 PM   #11
Re: Rpm drop
Originally Posted by doubletap4311 View Post
Idle air control. Pull it and clean in or
+1
Just replaced the one on my Vert for the same problem. Good as new now.
93CobraGuy is offline   Reply With Quote
Old 03-07-2011, 09:48 PM   #12
jjsg09's Avatar
What doubletap said do it and it will come back to live again. Common problem on Fords is carbon build up in idle air control valve.
Old 03-08-2011, 09:10 AM   #13
SaleenFiend's Avatar
Re: Rpm drop
Anybody could use a seafoam treatment from time to time. He is recommending cleaning the IAC/Throttle Body/TPS with a seafoam treatment as well as the rest of the Engine. This can only help.
This. IACs tend to get dirty and clogged. If that doesn't fix it you may have a problem with the valve.
Old 03-08-2011, 12:14 PM   #14
Re: Rpm drop
as said the MAF may need cleaning but its probably the IAC (idle bypass valve)
rpm drop classman Pre-2005 V6 Mustang 9 07-22-2010 07:59 AM
drop it lowww 04TRV6 Pre-2005 V6 Mustang 34 04-14-2010 02:31 PM
RPM drop Murph00 Pre-2005 V6 Mustang 12 07-16-2005 12:32 PM
How about a drop? Ken The Bar 22 09-16-2003 08:25 PM
need a drop hmongstang The Bar 20 08-12-2003 09:48 AM
05:31 PM
