Steeda Tri-Ax Shifter and beyond? - Mustang Evolution
Old 03-07-2011, 10:06 PM   #1
ColeJohnson's Avatar
Got it this morning, just installed it since I got off work... Went on a test drive; the difference is night and day. Pretty amazing, clean and crisp shifts and basically jumps to third.
Got my Bassani X-pipe and Flowmaster 40s coming in tomorrow and gonna install them next!
Then I'ma buy and install 3.73s..
Then what?
Old 03-07-2011, 10:08 PM   #2
Re: Steeda Tri-Ax Shifter and beyond?
I've got the Tri-Ax in my Cobra, very nice piece!
Got a tuner yet? If you don't, and you plan on more mods down the road, I highly recommend one!
93CobraGuy is offline   Reply With Quote
Old 03-07-2011, 10:11 PM   #3
I got an SCT X3!
Old 03-07-2011, 10:23 PM   #4
Excellent! You could always grab a set of underdrive pullies. Unless knowing my luck, you already have those too.
Old 03-07-2011, 10:25 PM   #5
Haha. I was going to get them a week ago, but didn't have the tools to install them yet so I went with the exhaust and shifter. Haha.
And don't underdrives sometimes cause problems..?
Old 03-07-2011, 10:27 PM   #6
Not sure about any problems with them. I just installed a set on my '86 vert last week. All I used was wrenches and a ratchet. The alternator pulley was a ***** though without an impact, but I got her done.
Old 03-07-2011, 10:41 PM   #7
Is the difference caused by them really that noticeable?
Old 03-07-2011, 11:24 PM   #8
I'm kinda thinking of going with 4.10s, actually... Should I get the tract-lok rebuild kit and the master bearing rebuild kit along with the gears? My car has almost 103k miles.
Old 03-07-2011, 11:26 PM   #9
Slow03GT's Avatar
I've had a Tri-ax on my GT for 7 years now and I love it. Lightyears better than stock that's for sure!
03 Dark Shadow Grey GT: 03 Cobra Brake Upgrade, H&R Super Sport Springs, Magnaflow Magnapack Catback, Anthracite FR500s with Continental ExtremeContact DW tires all around, Steeda Tri-ax, Maximum Motorsports Full Length Subframe Connectors, plus much more...
Slow03GT is offline   Reply With Quote
Old 03-08-2011, 12:27 AM   #10
I already have a few mods on the car anyway, so I couldn't really "feel" any difference. It's cold enough here, and my tires are pretty much gone enough that the damn thing breaks loose in 3rd gear.
If I were you and while everything is apart, I would definitely replace what I could, especially if you have the funds to do it now. That could very well save the trouble of doing it on down the line, and creating a headache of having to take things back apart again.
When I put the 3.73's in my old '84, I rebuilt the trac-lok and put new bearings in. So my recommendation is yes.
Old 03-08-2011, 12:55 AM   #11
Ah, good deal. And a good shop rate would be.. About $300-$400 for installing gears + rebuild?
Also, when I'm sitting still and I turn my steering wheel slowly, I can hear little clicks and creaks occasionally, I suspect tie-rods.. Is that a problem or normal?
Old 03-08-2011, 01:00 AM   #12
With that many miles on the car, things are going to wear out for sure. Tie rod ends, ball joints, struts, swaybar end links, all kinds of things with rubber on them. Another good idea for the suspension is a set of polyurethane bushings. Good stuff.
And yes, should be no more than $400-$500 to do the rear gears. You're getting the install kit as well right?
Old 03-08-2011, 05:52 AM   #13
Tib
Tib's Avatar
I'm looking at picking up a short throw myself this weekend...either the Tri-Ax or the Pro 5.0...haven't decided yet.
2003 Roush Mustang GT Stage 2 Package - Current 'Stang
1998 Mustang GT - Previous 'Stang
Tib is offline   Reply With Quote
Old 03-08-2011, 09:19 AM   #14
SaleenFiend's Avatar
I went 4.30s on my 01 Cobra... best gears I ever had.
Don't take it to L&S. I had a rear end they built that didn't go a few hundred miles without failing. The rear wasn't correctly shimmed for the clutches and had too much slack. My spider gears seperated enough to bind and crack (I could duplicate the problem with the rear still in the car and the cover pulled. They refused to fix the repair. I learned how to rebuild a rear end that day.
Old 03-08-2011, 09:39 AM   #15
I've gotta tri-ax. I gonna get the mgw eventually. I'll let y'all know if it is any better. It's supposed to be.
Alscobra is offline   Reply With Quote
Old 03-08-2011, 11:14 AM   #16
Yeah, I'm buying the install kit, master bearing kit, and the trac-lok rebuild kit.
Old 03-08-2011, 12:06 PM   #17
shifters are great, most wonder why they waited so long to do them lol
Old 03-08-2011, 12:55 PM   #18
I always wonder why the manufacture can't seems to make a peice like this factory. short throws and they can tweak the shifter a little for ride quality/noise reduction.
Old 03-08-2011, 12:58 PM   #19
If they did everything like that, we couldn't have such a good time modding.
Old 03-08-2011, 11:15 PM   #20
3.73 gears vs 4.10?
Old 03-08-2011, 11:22 PM   #21
3.73 gears vs 4.10?
K. I have driven a new edge with both these gears in them. The 3.73s weren't much better than stock and the 4.10s were insane in traffic. I went with 3.90s and couldn't be happier. Pulls really hard. My mpg got better and my rpm at 70 is 2200. Great gear. And at the strip I cross the line at about 5500 in 4th. With 4.10s your gonna need 5th,if it will see any track duty. I am very satisfied with my 3.90s. If your just sticking to the street perhaps 3.73s would be your best bet however they just didn't pull hard enough for me. If you are gonna strap a blower on tho 3.73s is max. 3.55 or even your stockers would be good
Built 2 Last TTT
Old 03-08-2011, 11:39 PM   #22
Built 2 Last TTT
Hm.. 3.90 sounds good then.
2016 Comp Orange GT (current)
Old 03-09-2011, 06:54 AM   #23
4.30s in my 01 was awesome and I never thought twice about going back to 3.90s or 4.10s..... you will probably like 4.10s or 3.90s.
Old 03-09-2011, 08:05 AM   #24
I want to know what study group ford gets that says "I love the car but can the shifter feel more like a wed noodle?"
Old 03-09-2011, 08:57 AM   #25
Yea, really.
Old 03-09-2011, 12:37 PM   #26
Thanks ya'll. :]
Old 03-09-2011, 01:54 PM   #27
Bahahahahaha. Nice
Built 2 Last TTT
Old 03-09-2011, 02:07 PM   #28
I've got brass shift cup insulator and brass fork inserts on order. Should stiffen up a bit.
Old 03-09-2011, 07:31 PM   #29
Yo let me know how the xpipe sounds.just got the bassani x ss no cats,centerforce df, steeda shifter. Can't wait to install.98 cobra alantic blue. Pic coming soon
VENOMOUS ONE is offline   Reply With Quote
Old 03-09-2011, 11:31 PM   #30
My flow40s got delayed so coming in tomorrow... But I have class and work all day. So probably won't be able to install them until the weekend. Dang. :/
Old 03-12-2011, 05:15 AM   #31
Bassani o/r x-pipe is now on my car and holy crickey.. I couldn't wipe the smile off my face on the test drive. It sounds AMAZING. Will post a video soon.
I get my flowmaster 40s on in a few hours at the exhaust shop. Gonna have 'em welded in.
Old 03-12-2011, 06:47 AM   #32
That's great to here money well spent.was it easy to install. Send me video. Still new to this site how do u get ur profile pic on their.
Old 03-12-2011, 07:03 AM   #33
Tib
Tib's Avatar
Just ordered mine last night...can't wait to get it since my stock is rediculously sloppy.
Old 03-12-2011, 07:12 AM   #34
What do u mean sloppy or guiet. What u get
Old 03-12-2011, 08:13 AM   #35
U got a cobra or gt u put the x pipe on send that video
Installed A Steeda Tri-Ax Shifter!! 93CobraGuy 1979-1995 Mustang GT 12 02-16-2011 02:26 PM
steeda tri-ax shifter electricstang Pre-2005 V6 Mustang 15 09-25-2005 08:57 PM
Brand New Steeda Tri-Ax Shifter!!! Mustang414 Mustang Parts for Sale and Wanted 5 06-14-2005 03:20 PM
Steeda Tri Ax Shifter **MEGA GROUP PURCHASE!!!!** Autobadges.com Mustang Parts for Sale and Wanted 0 05-21-2004 05:37 PM
06:52 AM
