Tie Rods or... - Mustang Evolution
Old 03-08-2011, 06:07 AM   #1
USAF_stang's Avatar
Tie Rods or...
Ok so this is prob a really bad time to ask lol. I had my tires balanced and then got an alignment. Even after that the steering wheel would like hop up and down when I was at around 60ish....go faster and it would either be hopping so fast I couldn't tell or it just wasn't as bad. Was told it could be my tie rod ends...but I'm figure it was most likely a bad tire balance? It did this as well when I would break really hard. (also should mention when I got it aligned I asked to guy to check my tie rods, whether he actually did it or not I couldn't tell you). Just looking for some advice on this.
USAF_stang is offline   Reply With Quote
Old 03-08-2011, 09:05 AM   #2
SaleenFiend's Avatar
Re: Tie Rods or...
More than likely a bad tire/tire belt or balancing. As far as the vibrating when braking you may need to resurface the front or rear rotors.
Do you have any additional slack in the steering that you can feel when turning from side to side?
Old 03-08-2011, 10:33 AM   #3
USAF_stang's Avatar
Re: Tie Rods or...
not that I remember....I had them balanced at wally world lol....so thats prob what my prob was...whenever my dad puts on the new wheels for me I'll have him check it and see if its still doing it. My old samurai...i realize it was an 85 lol did it horribly when breaking but just replaced the steering stabilizer bar and it fixed it...not sure how the steering works on a new car lol
Old 03-08-2011, 12:30 PM   #4
Re: Tie Rods or...
Tie Rod Ends are probably fine if you have no additional slack. I would lean towards tires being the main issue or cracked/bent rim - Which would be noticed on a balance machine.
Old 03-08-2011, 12:58 PM   #5
MC770's Avatar
Re: Tie Rods or...
My fox has like monster slack in the steering and my dad looked at my tie rod ends and they seem to be fine.
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 03-08-2011, 02:55 PM   #6
Re: Tie Rods or...
Could be a problem with the rack.
Old 03-08-2011, 03:40 PM   #7
-b?8tfabq jj c. Q
Sent from my iPhone using Mustang
04mach1lar is offline   Reply With Quote
Old 03-08-2011, 04:38 PM   #8
MC770's Avatar
Re: Tie Rods or...
Where would that be located? Gotta check that when I get the time
Old 03-08-2011, 04:38 PM   #9
Re: Tie Rods or...
The powersteering rack assembly bolts to the K-member.
Tie Rod Kamakanani0 Pre-2005 V6 Mustang 15 01-28-2011 08:10 PM
Tie Rods runvsofthisbull Pre-2005 V6 Mustang 20 05-08-2009 01:22 PM
Tie Rod: Smokedya95stang Pre-2005 V6 Mustang 3 05-10-2004 10:29 PM
94-95 and 96+ v6 rods, and 351w/351w truck rods tire Pre-2005 V6 Mustang 1 02-21-2004 01:37 PM
We Have A TIE! ---> Postwhore updates Ken The Bar 25 11-27-2003 10:12 PM
05:03 PM
