Tranny flush need help - Mustang Evolution
Old 03-09-2011, 01:23 PM   #1
So I want to flush out the tranny fluid in my 96 mustang gt, what kind and how much should I buy. I was reading up and from what I understood I should get royal purple synchromax but where i got confused is when i started reading about t5 and t45 and t3650. anyways just looking for how much i should buy. Thanks
johnnyspecs is offline   Reply With Quote
Old 03-09-2011, 01:33 PM   #2
Re: Tranny flush need help
transmissions can be finicky when it comes to what fluid. Different internal materials can act differently to different types of fluid. Overall you will probably be safe with a good fluid like royal purple.
You might wish to simply put the OEM spec fluid back in it
You have a T-45 so use what ever is recommended for that one
You can take your shifter off and pour the fluid in there (after you drain it) or you can use a pump to pump the fluid into the fill plug hole. The car needs to be level. Jack it up and crawl under there and remove the fill plug then the drain plug. Cant remember what side of the transmission they are on, probably the drivers side.
After drained you can choose to pour one quarter into it to flush out anything thats left~ then put in the drain plug and fill up until it comes out the top of the fill plug. If ford recommends XX quarts then just put that and cap it off and your done.... I need to change mine again its been a good while.
Old 03-09-2011, 01:50 PM   #3
I used amsoil synchromesh in my t45. No complaints and I put in 3.5 liters
Built 2 Last TTT
Old 03-09-2011, 09:23 PM   #4
mz98snake's Avatar
Anybody have any luck with royal purple max atf?
mz98snake is offline   Reply With Quote
Old 03-09-2011, 09:28 PM   #5
I have read some horror stories about it eating seals. Racing fluids are meant to be changed often and racing trannies are rebuilt often. I know enough that I won't use it. I know amsoil makes a quality product especially gor extended drain intervals .Even motorcraft is good if changed often.
Built 2 Last TTT
Old 03-09-2011, 09:31 PM   #6
mz98snake's Avatar
Built 2 Last TTT
Damn. I got 5 qts of it in my toolbox and need a flush. I also hear gear oil isn't good. Hear lots of good things bout rp syncromax. Any further opinions. I know amsiol has a good rep, very hard to find locally.
Old 03-09-2011, 09:37 PM   #7
Use it then. I have no experience with it. Only what I have read online. If you have an issue dump it. I get amsoil wholesale so I don't even bother with anything else. Go to their website,for 10 bucks they make you a prefered customer and you can get it at wholesale too. That fee pays for itself in 1 oil change. And when I order its on my doorstep in 2 days.
Built 2 Last TTT
Old 03-09-2011, 10:20 PM   #8
mz98snake's Avatar
Built 2 Last TTT
Sounds like a plan. I can at least try it. My trannys a lil hurt any way. Second grindes if I don't granny shift.
Old 03-10-2011, 11:49 AM   #9
Mine used too. Then I read in one forum to leave the tranny fluid half a quart low. So when I switched to amsoil I did. I haven't had a grind since. I don't know if it was the fluid change or leaving it a bit low but it seemed to help. I have a t45 tho...I don't know what tranny you have
Built 2 Last TTT
Old 03-10-2011, 07:35 PM   #10
mz98snake's Avatar
Built 2 Last TTT
Mines a t45 as well. That's good to know. Which amsiol type did u say was for our trannys?
Old 03-10-2011, 07:38 PM   #11
I used the synchromesh. I am pleased with it. And you can't beat the extended drain intervals
Built 2 Last TTT
Old 03-10-2011, 07:40 PM   #12
mz98snake's Avatar
Built 2 Last TTT
Very nice and thank u for the prompt responses.
Old 03-10-2011, 07:42 PM   #13
No problem. I hope everything works out for you
Built 2 Last TTT
Old 03-10-2011, 07:44 PM   #14
mz98snake's Avatar
Built 2 Last TTT
Thanks. I'll find out after I put my shortblock back together. Hopefully next week.
Old 03-10-2011, 07:47 PM   #15
If you don't mind please keep the forum informed of your findings. Any user info good or bad is good to have on the record for other members to see.
Built 2 Last TTT
Old 03-10-2011, 07:57 PM   #16
mz98snake's Avatar
Built 2 Last TTT
Of course. I'll first post how the RP max atf worked out. Run that for awhile and try out the syncromesh. Also on one last note about amsoil, seeing as this thread is slightly jacked. I noticed they have 2 types of 5w30. Which would u recommend for my 98 cobra 4v. Just freshened up a used shortblock and swapped it in. Mileage around 90k
Old 03-10-2011, 08:13 PM   #17
Amsoil has a line of oil called SSO. Signature Series Oil. It's the best oil they make. It's a 0W30 weight. That would be perfect and it's an extended drain interval oil so if you use it with the amsoil oil filter is good to 25000 miles. 15000 if your hard on it. The next best oil is the xl line. It has more zddp and it's for higher mileage motors. Either of those are a great choice. The xl is good for about 10000 miles if your beating on and over 15000 if you drive semi normal. I have read alot on oil in the past few years and synthetic oil has come leaps and bounds due to it's durabily and resistance to shearing. If your going to change it at say 3000 or 5000 miles it's not really worth going with synthetics because even dyno oil the add pack isn't depleted and sheared thin. Just something to consider.And I would like to hear how that rp works for you. Thanks
Built 2 Last TTT
Trasmission fluid flush... Blackedout General Mustang Discussion 7 03-08-2011 12:46 AM
How to Flush the Clutch Fluid on an 07 mxw1090 Pre-2005 V6 Mustang 4 06-09-2010 04:42 PM
power steering flush 968 1996-2004 Mustang GT 0 06-30-2009 09:20 AM
Transmission Flush runvsofthisbull Pre-2005 V6 Mustang 13 06-26-2008 11:01 AM
How to: Steering Fluid Flush? cagedthought Pre-2005 V6 Mustang 2 10-24-2004 09:30 PM
06:09 PM
