new clutch problems - Mustang Evolution
Old 03-10-2011, 06:13 AM   #1
new clutch problems
Jus got a new ram clutch installed on my cobra, but the first bunch of times starting in first the car shakes as I'm gettin into gear but after first its fine. It seems like it steadily starting to go away I'm guessing the clutch just needs to break in ?
nasty99 is offline   Reply With Quote
Old 03-10-2011, 11:44 AM   #2
A clutch needs 500 city miles to break in before you give er full pedal. I cooked a centerforce df by not breaking it in properly. I figured give er....bad idea. Another 700 out the window. It shouldn't be shaking tho.
Built 2 Last TTT
Old 03-10-2011, 12:41 PM   #3
Clutches are like brakes, they have to bed in. Did you replace the flywheel or have it turned before the clutch was installed?
93CobraGuy is offline   Reply With Quote
Old 03-10-2011, 12:45 PM   #4
Re: new clutch problems
if someone installed it let them know now that you are noticing this rather than 500 miles from now when they can blame it on you and not their install etc. It might be nothing but its always best to let them know and talk to them about it.
Old 03-10-2011, 12:50 PM   #5
Good advice. Bring it to their attention
Built 2 Last TTT
Old 03-10-2011, 01:43 PM   #6
Yea dude the place seems shady but its a friend of a friend. Nevrr had this problem before, it almost feels like the shaking that happens before it stalls out when someone is learning how to drive stick. Like dude I'm so livid. I'm bringin it back to the shop tomorrow. There really isn't a mechanic out there that's trustworthy anymore. I called him he said that it could be the flywheel. If it is I'm flipping out. They did say that they put a nice glaze on it or something idk
Old 03-10-2011, 01:47 PM   #7
Built 2 Last TTT
And the guy that worked on it said that it doesn't even need to be broken in after the first couple shifts through the gears it'll be ready. Which I also thought was weird.
Old 03-10-2011, 01:49 PM   #8
Fyi folks the reason why I got a clutch was because I needed to get my throwout bearing fixed, which they did but he didn't call me when he had the tranny open to see it, but it still makes a little bit of a whining sound UNTIL I push in the clutch and he said its the bearings or whatever inside the tranny and it will still last another year or two..like WTF dude.
Old 03-10-2011, 01:54 PM   #9
Take it back. Sounds like they just put the clutch on without turning the flywheel. Smetimes you can get away with it with no problems, but sometimes not.
Old 03-10-2011, 02:24 PM   #10
+1
Alscobra is offline   Reply With Quote
Old 03-10-2011, 02:25 PM   #11
Well every clutch manufacturer website that I look at before I bought my centerforce said 500 city miles before you give it full power. So I really don't know what to say.
Built 2 Last TTT
Old 03-10-2011, 02:27 PM   #12
Alright man thanks. I just wish this whining sound wasn't there... You'll probably see me making another thread about that too. Fml.
Old 03-10-2011, 02:29 PM   #13
Built 2 Last TTT
No dude I believe you cuz my boy on here put the same clutch in hiz 04 mach 1, and he was tellin me I need about 300 for the ram clutch. But like I said I'm takin it tomorrow hopedully its just nothing.
Old 03-10-2011, 02:41 PM   #14
Yup, 200 to 300 minimum. Same concept as brakes. Ever change your brake pads and then after a few days they seem to stop the car better?
Old 03-10-2011, 03:04 PM   #15
04machazblue's Avatar
Yea when I was with you Dave and he said u don't have to break it in it seemed strange and like i told you I broke my clutch in for 300miles babying. And he said he did resurface the flywheel. Does it sound like a chattering noise?
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
clutch engagement problems 1996v6stang Pre-2005 V6 Mustang 11 05-19-2010 08:31 AM
2006 Mustang clutch problems brokenford Pre-2005 V6 Mustang 1 03-18-2008 12:48 PM
clutch? roach 1996-2004 Mustang GT 5 03-23-2007 01:58 PM
best clutch ? jedwards242000 Pre-2005 V6 Mustang 5 04-09-2005 03:21 PM
new clutch Johnny D Pre-2005 V6 Mustang 9 03-05-2004 07:47 AM
» Members Mustangs
98 GT
98RedGT
RED
Randl114
Add your Mustang
07:09 PM
